Does the 533mm Pro pair well with Samyang 135 and 3nm narrowband filters?
11 replies426 views
Photon_Collector avatar
Any experienced users have opinions/example images (masters or finished image)?
CoyoteAstro avatar
I used this Combination to shoot the veil nebula recently https://astrob.in/fb59rf/0/.  I did notice some out of roundness in the corners but i never worked out if it was just tilt or if it was in fact the lens. blur exterminator took care of it regardless.
Jan Erik Vallestad avatar
This is basically the same as the 2600mm and I have had and used both with this lens. I have used both 3nm and 4.5nm filters as well as broadband. Something to consider about 3nm Ha is the exclusion of Hbeta. Some NB examples:
Not done with the Samyang, but the Nikkor AI 135mm F/2.8 using the 533MM, 4.5nm Ha & 3nm Oiii/Sii: https://www.astrobin.com/nvkfa6
ASI533MM, Samyang 135mm, 4.5nm Ha - This was purely a backfocus testing image i made: https://www.astrobin.com/1ds9r7/0/
ASI533MM, Samyang 135mm, 4.5nm Ha, 3nm Oiii: https://www.astrobin.com/rnsy4e/
ASI2600MM, Samyang 135mm, 3nm Oiii/Ha: https://www.astrobin.com/p5xcmy/M/
3nm filters will work just fine, but I would perhaps consider 4.5nm to include Hbeta as well. If you intend to shoot at F/2 you would be better off with ones made for fast optics.
Not getting an entire field of round stars, and slightly off nebulosity like seen in my test image, is very common even on smaller sensors. This is purely down to tilt/backfocus which is crucial at those F-Ratios, each fraction of backfocus matters a lot. So spend some time adding 0.1mm spacers to the image train in order to evaluate the stars. An easier option would be to stop down slightly, which perhaps is necessary on certain copies due to poor QC.
What I found to work for me was to try and get the backfocus as best as possible so that the stars were workable, then I just spend a few minutes re-shooting them slightly stopped down to F/2.8 or F/4. I've got some step down rings for that purpose now.
Helpful Insightful
Nooa Jutila avatar
Note that the Samyang 135mm might be too fast for some 3mm narrowband filters. Bandpass shift may affect your images.
Well written Concise
Jan Erik Vallestad:
There is no such a thing. The Balmer sequence is Ha - Hb - Hg... and the visbile light frequencies of the series are:
656.3
486.1
434.0
410.2
397.0
So maybe you are referring to an OIII filter but that needs to be much wider then 4.5nm to include both the two emission lines of OIII and Hb.
Concise
Yes, thanks for correcting me. It went a bit fast and I unconsciously swapped Hb for Nii which is excluded with 3nm but included in both 4.5nm and 5nm.
Mark Savan avatar
I'll point out the obvious here … you will lose a great deal of potential field of view with the 533.  I'm not sure what your other options for sensors are but one of the beauties of the 135mm lenses is the expansive FOV .. which you'll only be able to capture with the 533 via mosaic
Concise
Monty Chandler avatar
The issue with the 533 sensor is that it is a massive crop of your fov.  Unacceptable to me as I buy my scopes with their focal length and fov in mind.  Good luck.
Nearly 25 square degree of sky, seems pretty extensive to me...
Tom Victor avatar
The Samyang 135 pairs very well with 533mm Pro. You will find many examples on my site.
However I use 6.5nm high speed narrowband filter as I image at f2.
https://www.astrobin.com/g4zej6/?nc=collection&nce=31225
https://www.astrobin.com/axqg8y/?nc=collection&nce=31225
https://www.astrobin.com/mujxll/?nc=collection&nce=31225
https://www.astrobin.com/6cjpz2/?nc=collection&nce=31225
Rob Lyons avatar
I wouldn’t recommend this combination. The Samyang is very wide for deep sky imaging, but the 533 is small sensor. For a wide view you want a wide sensor. A full frame or APSC size chip would be a much better pairing. The field of view of your image will be cropped 2.7x compared to a full frame sensor, which that lens supports.
Well written Helpful Insightful Concise
Ok so I was hoping to save some $$ but I think I will go for the 2600MM pro to get the best match
Moving on from DSLR to either Mono or OSC
Please forgive what I’m sure is a well-worn topic. I have been at the hobby for the last year and have got results I am pretty pleased with, with a modded Canon 700D. I think I am in the hobby for the long haul so am saving now to get a dedicated ast...
Discusses camera choices and imaging results relevant to experienced user perspectives.
Sep 2, 2025
Flats adding to images instead of subtracting in PixInsight WBPP
Astro Friends, I have been imaging for about 5 years and have been successful using refractors and mono imaging. I have branched out this year and now have an SCT and mono setup. I am seeking help with my flats which seem to add themselves to my imag...
Technical processing experience with imaging systems and workflow troubleshooting.
Jan 2, 2026
Astro pixel Processor - How to combine a OSC broadband image and Extracted Ha and OIII from a dualband filter?
Hello All, I have a 2600MC-pro and have been using APP for a couple of years. I normally am only using 1 filter so no issues stacking. APP has been great. Now I would now like to take broadband subs and add the Extracted Ha and OIII from my antlia AL...
Advanced image processing techniques for combining different filter data.
Sep 5, 2025
