Askar C2 Filter Halo Tests with NIR sensitive OSC cameras
22 replies711 views
astrovic47 avatar
Just sharing my tests with the Askar C2 (SiiOiii) dual narrowband filter with a One-Shot Colour camera to anyone who may be looking at budget options for SHO imaging. Please feel free to to critique any of my methods, interpretations, or assumptions as that's how we all improve our understanding.
tl;dr
When using the Askar C2 filter with OSC cameras that have increased NIR sensitivity (and lack a built-in UV/IR glass over the sensor), the addition of an external UV/IR used in conjunction with the C2 will likely be necessary.
Background
For those using OSC cameras without a built in UV/IR cut glass over the sensor, it is always recommended to at least use an external UV/IR cut filter to reduce star bloat. It's also generally agreed that using narrowband (dual, tri, etc.) filters can also stand in place of a UV/IR cut filter as by their nature, inherently block anything except the target wavelengths.
While I still think that is generally true (as shown with the SV220 filter), I think a caveat must be stated with some filters, in this case with the Askar C2 filter.
Conditions & Equipment
The test images were collected on Sep. 16, 2024 in my Bortle7/8 backyard, with a near full moon. The equipment used is as follows:
  • Camera - Touptek ATR585C (AR Glass option), HDR mode, gain 100, offset 1200, cooled to -10c.
  • Telescope - Skywatcher Black Diamond 80ED doublet refractor, with a 0.8x FR/FF.
  • Filters - SVBony SV220 7nm (HaOiii), Askar C2 (SiiOiii), SVBony UV/IR.
Process
For each scenario, the same two targets were used and images of each target were completed before changing filters. Before imaging with each filter, focus was achieved on a bright star using a Bahtinov Mask. The only variable changing between scenarios is the filter.
The first image was centered around the bright star Alderamin (same as used for focus), and consisted of a stack of 10x30sec exposures.
The second image was centered between NGC7635 (Bubble Nebula) and the open star cluster M52, and consisted of a stack of 10x120s exposures.
The images were all processed the same way with the following procedure:
  • Stacking in DSS, only bias calibration added.
  • Siril, Background extraction, Remove Green Noise, Auto-stretch. The screen results were then saved as is.
Results
SV220 - Alderamin (please note I rotated the camera slightly after taking this photo):
Askar C2 - Alderamin:
SV220 - Bubble:
Askar C2 - Bubble:
Askar C2 + UV/IR - Bubble:
Continued in the next post.
Well Written Helpful Insightful Respectful Engaging
astrovic47 avatar
Discussion
As can be seen, the SV220 filter is doing a good job preventing halos with the exception of the bright star Alderamin, but I think that is acceptable given the cost of the filter. I should also note that the type of halo it shows (a thin ring) to me, is kind of pleasant? It almost adds the appearance of a lens flare which I personally don’t mind.
Now compare the background stars in the Askar C2 image. While there isn’t the same thin ring halo on Alderamin, there are definitely some unique halos around some, but not all, of the stars.
Unfortunately, I find these donut looking halos unappealing, and they also provide a challenge when using star removal with Starnet.
Is it an NIR leak?
When I first ran into this problem a few months ago, one person had suggested to me that the filter may be ‘leaking’ NIR light. I unfortunately don’t own or know anyone that has a spectrometer that can verify this, but by drawing some conclusions from the results, it does seem like it’s the culprit.When qualitatively looking at the stars with the most severe halos (See number 1 above) I notice that the star appears orange in colour. This would suggest that it is a cooler star, and possibly emitting more light in the NIR.
If I review the stars in Stellarium, I can use the Colour Index (B-V) value as reference, where negative numbers indicate hotter stars, and positive numbers indicating cooler stars. Star 1 has a value of 2.30 indicating a cooler star emitting light at longer wavelengths. Star 2 has a value of 0.48, still cooler but not as cool as 1. Finally Star 3 has a value of 0.29. At least for this small dataset, a trend can be seen where stronger halos are proportional to the (B-V) value. The higher the (positive) number, the stronger the halo appears. Take this with a grain of salt as I am by no means 100% of my assumptions, and the data set is extremely small.
NIR response of the Camera.
Below is the published spectral curve of the Touptek ATR585C using the Sony IMX585 sensor. Beyond 850nm the bayer matrix appears irrelevant and the response in all 3 colour channels is nearly the same.
If I review the halos in each colour channel separately, I don’t discern any noticeable difference which further pushes me in the direction of NIR being responsible for the halos.
Optical Density.
A filter specification that I had never heard about until I started looking into the difference between the SV220 and the C2 (aside from the band passes and band widths) was that the SV220 has an OD value of ≥5. While the C2 has an OD ≥3.Again, I’m by no means an expert on this property, but fundamentally it is the ability for the filter to reduce or attenuate the incoming wavelengths it’s not designed to pass.
In the case of the two tested filters between roughly 300-1000nm. From some quick googling, the difference in OD3 to OD5 is 1,000x and 100,000x respectively.
Is it just a bad copy of the filter?
When I was originally looking at this issue with a different camera (Player One Neptune CII) that also has increased NIR response, I reached out to Askar to see if they had any suggestions. They simply offered to replace the filter if I sent it back to them. Luckily my local astronomy store was kind enough to also reach out to them and agreed to do the exchange locally, which I appreciated.Upon receiving the new filter, I noticed the same issues but decided to keep it anyways because…
Solution
A simple solution one person had suggested to me (assuming the problem was NIR) was to simply add an additional UV/IR cut filter and see what happens. And as the results show, it fixes the problem. While not ideal if you can only add a single filter to your imaging train, I luckily can put it on the nosepiece of my field flattener and enjoy using the filter in my drawer without halos.[b] [/b]
Zoomed in on the bubble nebula, despite the poor focus on my part of the image on the right, the donut halos are eliminated by the addition of the UV/IR filter. Lower image pair shows the dramatic difference adding a UV/IR filter has made on bright stars above the star cluster.:
Conclusion
So for those who made it this far, thank you. Hopefully most of what I said makes sense. Based on my tests it seems to me that Optical Density (OD) may be a critical specification when looking at narrowband filters for OSC cameras that are sensitive to NIR and don’t have a built-in UV/IR glass over the sensor. I’m unsure what OD value some of the higher end filters have, but admittedly didn’t spend a lot of time looking.
My best guess is that the Askar C2 being one of the cheapest dual narrowband filters on the market, corners have to be cut somewhere. One of them I suspect is using the lower OD value. Assuming that their published spectrum of the filter is 100% accurate. Their D1/D2 line of filters indicate that they are OD5. It would be interesting to see if one of these filters shows the same halos or not but at nearly 3 times the price it’s not within my budget.
But as I said at the very beginning, the addition of a cheap UV/IR filter is an economical way to ‘enhance’ the filter making it at least as good as a more expensive budget filter when it comes to rejecting these supposed NIR halos.
Thanks for taking such a detailed look at this. I'm wondering if this is a problem with reflecting optical systems as well? I would suspect that it might still be in the far IR, just not to the same extent.
astrovic47 avatar
I'm glad you found it insightful, I forgot to add a few additional photos showing the effect of adding the UV/IR with the C2.
To your question, I believe the halo problem is, or at least majority due to the filter and not the telescope design, assuming the issue is NIR leak. This is shown by adding the UV/IR filter in front of the C2 and the elimination of the halos. According to the published graph of the filter, it should be cutting out everything after sulfur out to 1000nm like the SVbony filter.
But can also see that the halos may be worse because of the refractor as I don't think it's possible to simultaneously have NIR and VIS light at the same focus? Would be interesting to see the results with the same setup but with a reflector instead.
deleted avatar
@astrovic47 , Yes.. Thanks for taking the time to detail this.... I'll have to re-read your post a couple of times to take in all of the info
I purchased the C1/C2 filter set because as you mentioned it being the cheapest dual narrowband filters on the market.. I also looked at the D1/D2 set, but it is over twice the price of the C1/C2 set....
I've been working on a summer project, imaging the Wizard nebula to try out the new filters with my Z73 with ASI533MC setup, and to learn PixInsight at the sametime... I'm going to have to, go back and look at my masters... but after looking at the spec sheet for the 533MC, it appears only to have a AR window (anti-reflective)... so it looks like I may need to add a IR cut filter into the optical train..
I've always wondered if filters could be stacked together.. could I install a UV/IR filter into the optical train, and leave it in place to be used with the C1/C2 filter set?? or would it need to be removed depending on the object being imaged?
Thanks
astrovic47 avatar
@Phil Eng you can definitely 'stack' filters as I have to do when using the C2. For my setup the narrowband filters get swapped in my filter drawer that is attached the camera. Then on the nosepiece of my field flattener is where I put the UV/IR cut filter.
A thing to keep in mind is that while my method works, adding additional elements in the imaging train can also lead to some other problems like reflections between components and a reduction in the overall signal reaching the sensor (although this may be negligible?).
If you have the time and are able to post an image with the C2 (or C1) I'd be interested to see if you also see halos. I looked at the spectral graph for the 533MC sensor (below) and at 850nm the response is around 35% whereas on the 585 sensor (second image below) it's around 75%. Again assuming the problem with the C1/C2 filters is NIR leak, I wonder if the lower NIR sensitivity of the 533 sensor is enough to make the halos much less severe.
IMX533
IMX585
deleted avatar
@astrovic47
Here are links to a Google drive that I just setup to share the master PixInsight stack for both the C1 and C2 filters..
Specifics for each of the filters:
C1 Total acquisition time: 8.8 hr
C2 Total acquisition time: 14 hr
Stacked in WBPP
Processed In PixInsight
Will be adding more acquisition time to both as weather permits
Equipment
WO Z73 with field Flattener Flat73A
WO 50mm Guide w/ASI120mm
Camera ASi533MC-Pro
AM3 mount
The master images are 180 deg out of orientation, due to me taking the optical train apart to clean out some dust bunnies, and I wasn't very carefull on making sure the camera orientation was the same when I put it back togeather... There is No UV/IR filter is in the optical train, but that will be changing
Hopefully the link to the Google drive will allow folks to down load the masters, if not let me know... Also if I need to convert these to fit files... Let me know that as well
C1:
https://drive.google.com/file/d/1-2PUi099QnKouo4ZoVJdqXL8edPVNtMN/view?usp=drive_link
C2:
https://drive.google.com/file/d/1-BCAgWKvt0ldItfogjmTuyYNK2jcYdMZ/view?usp=drive_link
astrovic47 avatar
I did download both files but I'm not seeing a way to open them in Siril unfortunately, looks like they may have disabled that feature in their more recent releases?
If possible, if you can export in either .fit or .tif would work for this purpose.
deleted avatar
@astrovic47  Yeah... I think the .xisf format is PixInsight format only.... let me convert to .fit format and upload them, will provide a new link to the .fit format
deleted avatar
@astrovic47
Here are new links to the fits formated files
C1: https://drive.google.com/file/d/1-Gz3_0wXtbcwPy_9wiEqYrfqro6U9o5-/view?usp=drive_link
C2: https://drive.google.com/file/d/1-FjmcqC8hHBG6kKp_fgNjBaGc1DwdVk1/view?usp=drive_link
deleted avatar
Weather looks good for tonight… going to try and get another 3hrs of C1 - Ha/O3 data
astrovic47 avatar
@Phil Eng thank you for the images, they are definitely adding some interesting and useful information to these tests.
I ran both your C1 and C2 images through the same simple processing as described in my original post to be consistent. I also searched astrobin for an amazing image of the Wizard nebula that contained more or less the same field of view, shot with a 533MC pro and a doublet refractor which led me to the following image from Anthony MICHEL.
https://www.astrobin.com/mbgf1j/0/
I only really found one star exhibiting the same extreme donut halos as in my tests, and even more interesting, it was really only noticeable on the C2 image.
This group of stars is located above the hat of the wizard and the brightest star in the images is at the centre of a dust cloud. There is one star in the area (A) that I've annotated in the below image that when compared to the reference image, should not be that big especially in the C2 image.
Unfortunately Stellarium doesn't have this star as clickable therefore I can't determine it's (B-V) index. But if we simply assume based on star colour, then we can see that it's subjectively one of the more orange-red stars in the field. And following the original thought that it's being caused by NIR, it certainly adds support.
So why is the halo either not present, or much less noticeable on the C1? I can't say for certain maybe it's more difficult to produce the C2, or maybe  it just wasn't manufactured as precise as the C1?
Another interesting difference between the C1 and C2 is that when comparing the halo in the individual RGB channels, on the C2 there isn't much difference (same as I observed) but on the C1, only the red channel really shows a halo. As to why that is, that might be reaching the limit of my speculation
In any case, I would still say do some tests by adding a UV/IR filter and see how much of a difference it makes in the stars. And I suspect that if I image this region with my setup I'll see an even stronger halo around 'star A'. Perhaps I'll try on my next available clear night.
deleted avatar
@astrovic47
Wow... I would not have noticed this difference in a million years.... I ordered a Optolong UV/IR cut filter to put into the Z73 optical train, pretty much like you've done, somewhere in the Flat73... I plan on leaving it in place as a permanent part of the optical train, and if I need something without the UV/IR filter... I'll just use the Redcat51
the weather here in my location isn't looking to promising this week-end, and the phone weather app says that Monday/Tuesday night will be the first clear nights going into next week... With any luck I'll be able to shoot both Monday and Tuesday nights. Monday with the new UV/IR + C1 filter, and Tuesday with the UV/IR C2 filter. Now that I have a reference to which star showed the most halo effect, I'll see if processing on PixInsight yields the same results..
Martin Jordan avatar
Great write up of your observations.  It has halted me procuring the C1/C2 filters pending further research.  The vendors often post filter bandpass characteristics, but frequently leave off the NIR.  Were you able to find bandpass curves that included filter NIR characteristics?
I own and use an IDAS GNB filter which does have known NIR characteristics.  I do not notice the “ringed stars” with it that you observe with the C2 filter, but I shall go back and check.  I have an inage and subs of the M52, Bubble, and Lobster Claw Region that may contain the same stars.
Thanks again for reporting your findings.
Well Written Insightful Respectful Engaging Supportive
astrovic47 avatar
@Martin Jordan Unfortunately no to the graphs with the NIR range shown.
Another thing that I've been thinking about is re-doing this test as I now own a Carbonstar 150 and there may be an added or at least an exacerbated effect when using an ED doublet refractor. However that will likely have to wait until the spring is my winter has been particularly cloudy with the occasional short windows of clear but 'too cold to try and experiment' temperatures.
Alan Brunelle avatar
Being short on time and only having very quickly read through this thread, I think you are on the right track as to the cause of these tight halos.  Please see my experience in which I report in this post: https://astrob.in/cd9mc1/C/.  Note that my description also relates to a Forum post I made on this issue.  But all that the information that I see you provided here is consistent with what you are demonstrating so well in this thread.
Aside from the IR signal, likely the reason that all stars or most bright stars do not show these bright donut halos is that many are not strong emitters of NIR/IR.  Note the uncanny correlation of stars with these distinct donuts, regardless of brightness, to Long Period Variable (LPV) stars.  In fact, when I first made the correlation in my images from short f.l. lenses, I thought I had found a great way to identify LPV!  Alas, it may be, but for all the wrong reasons!  As you will see, the contribution to this artifact from some filters seems to be limited to filters manufactured with interference methods.  It is known that interference filters are very dependent on the angle of incidence of the light onto the filter surface.  So it is just that these filters were not designed to work at short focal lenghts and it seems to be the IR light that escapes the filtration effect easiest.
For me this was even with cameras with poor NIR sensitivity.  How can this be?  Well I urge you to get on Simbad, call up images of your fields choosing one of the NIR cameras that are available and you will see that uniquely for these stars, that the NIR/IR emissions from these stars is orders of magnitude greater than in the visible bands!  Some stars, essentially invisible in the visible can become the brightest stars in NIR/IR!  So, even with a camera not designed to see NIR, if you give it 100x, or more, the amount of NIR light, even non-IR optimized cameras will see it and make those halos.  Also, consider the NIR halos occur because NIR is either not well focussed by the optic, basically because the optic is not designed to do so.  My solution with those optics that give me the optic is to ditch the L-Pro (which I assumed was serving as my IR/UV cut filter) and bought a dedicated IR/UV cut.  As you state, that was the solution and worked very well.  On any other optic, my L-pro is still my go to.
Also be aware that IR leaking through any filter will affect star color when using a OSC camera.  (It may also do so with RGB, but don't have the time to think through that problem, though the color filters used during RGB capture are probably much better at IR/UV cutting than the Bayer layer.)  The reason is that the Bayer filter layer on a OSC camera is designed to work on a camera that has the IR cut filter as part of the system.  The R, G, B, filters in the Bayer layer are perfectly transparent to IR.  I use a camera for IR work that has the extended NIR range, but also has a Bayer layer.  When I image only in IR (using an edge filter that removes all vis light), my images are colorless.  With my defective fast f.l. setups that lead me to investigate the issue, I noted that stars with high IR signals appeared off-color.  Depending on the amount of IR light leak, the result will be a color-skewed image of many stars.
In any case, thanks for bringing this up again, since I think it could help those who may be struggling with this issue with this sort of filter and fast optics, which is more popular than ever.  As long as this thread is visible....   Unfortunately, all these tidbits of wisdom on a form such as this seem to fall away with time and get lost much too soon!
Franco Grimoldi avatar
I hate to read this... but I'm thankful it exists. I was struggling to understand the nature of the halos I got on my C2 first light, it now all makes perfect sense.
Last night I used the Askar C2 for the first time, paired with a Rokinon 135mm F2 and a ASI585MC Pro. I bought the filter to complement my Svbony SV220 7nm HO filter, which works wonderfully.
These are the red channels from each filter. They are 30x5m (2h30m) stacks each with minimal processing and a simple STF:
Svbony SV 220 7nm HO:
Askar C2 SO:
The halos are hideous, full stop.
I do have an UV/IR filter but no easy way to attach it to my image train. I'll need to think of something or forget about using the C2 for the time being.
Helpful Concise Engaging
astrovic47 avatar
Hi Franco, I'm glad that my findings are useful, but not glad that you have the same issue I encountered.
There might be able to find a step down ring hat matches the filter diameter on the front of the 135mm lens and then would allow for a 2 inch UV/IR filter to be added to your imaging train.
Unfortunately not ideal, but I guess some cost cutting was used when designing these particular filters.
As a side note, SVBony now makes a Sii/Oiii counterpart the the SV220. Given how good the Ha/Oiii version is, I'm very tempted to get the new one and ditch the AskarC2.
Hi @astrovic47 ,
Many thanks for your response and advice 🙏.
I do have a 3D-printed step down ring that I used to attach the SV220 in front of the lens back in my Sony mirrorless days. As far as I can see, it's my only option. My clear aperture drops to 44mm and the effective focal ratio to ~ f/3, losing half of the light. It would make the filter even less effective, but otherwise I find it unacceptable.
Fortunately, there are a couple of clear nights ahead and I can give it a try. I want to check how much effort would take to gather a half decent SII and OIII signals.
I saw she Svbony SO alternative and, as you said, looks very very tempting, considering how good the HO turned out.
Hopefully, more to come soon.
Thanks again,
Respectful Supportive
Minor updates:
I did some research and found that there are many options of 77mm UV/IR filters for the Rokinon 135mm:
https://www.bhphotovideo.com/c/products/ir-cut-filters/ci/16886?filters=fct_circular-sizes_27%3A77mm
Some of those are in fact intended for DSRL/Mirrorless cameras that were modded for "full spectrum", such as this one:
https://www.bhphotovideo.com/c/product/1688193-REG/kolari_77mmhapro_77mm_ha_pro_filter.html/overview
The decription:=productDescription_UbV5SNP5Eo=js-injected-html text_UbV5SNP5Eo
The 77mm UV/IR Cut H-Alpha Pass Pro Lens Filter from Kolari Vision cuts UV and IR light when your camera's native UV/IR filter isn't strong enough and lets some IR light pass through. It can also be used in combination with ND filters that do not cut out IR light. And it also works as a protective filter, as it causes no color cast nor exposure correction. This pro version features multicoated Schott B270 glass in a slim, knurled brass ring threaded on both sides. (The optional standard version has an aluminum ring.)
Alternatively, this filter can be used with a full spectrum modified camera to provide more than four times the sensitivity in the H-alpha (Ha) line compared to most cameras' native sensitivity, and greater than six times the sensitivity in the sulfur II line. A full spectrum modification entails manually removing the camera's low-pass filter and replacing it with a clear filter. (Kolari Vision can make the modification for you at a cost if you send in your camera to them.) This Ha filter has a similar transmission to Kolari's hot mirror filter, but with an expanded spectral response covering the H-alpha and sulfur II emission lines, making it also useful for astrophotography.
Looks great on paper... but then I see that it costs $125. On top of that, this solution won't work when I upgrade the lens to a telescope, planned to happen this year, and the C2 wasn't very good spec'ed to begin with...
So... I ordered the Svbony SV220 7nm SII-OIII, directly from the website for $186, expedited shipping included. It will take a few weeks to arrive, so I'll use this week's good upcoming nights to accumulate a few more hours with the C2 and the 2" UV/IR in front of the objective lens, just to try to wrap up my SHO Seagull and confirm, yet again, your hypothesis.
How much transmission do you think would you effectively get from that filter @ f/2 or for that matter @ f/3? I bet you it isn't going to be much and less than you think…
How much transmission do you think would you effectively get from that filter @ f/2 or for that matter @ f/3? I bet you it isn't going to be much and less than you think...
It's a great question. From Cuiv's analysis, I understand that the wider band-passes help to compensate for any band-shifting on fast systems. Fortunately, I won't need to try doing any math as tonight I have a great forecast and I'll be able to get shots for side-to-side comparisons.
Regardless, the Svbony SV220 SII-OIII has already shipped, I should be able to put it into action in a few weeks.
Update!
I used the 2" UV/IR filter in front of the Rokinon 135mm and, effectively, the donut-halos were gone.
Unfortunately: the SO+UV/IR tests were done from my backyard, a bortle 7A sky, and the filter didn't really make it.
The shots (same minimalist processing + STF stretch):
. SO - 2½ hours @f/2 - Bortle 4B (mag/arcsec² = 20.60):
Donuts galore.
. SO+UV/IR - 2 hours @f/3 - Bortle 7A (mag/arcsec² = 18.03):
The donut-halos are gone, but so is the nebula. I also see a weird rainbow-like streak coming out of the lower right corner. I know it's not fair to compare a Bortle 4 with a Bortle 7 result, but I want to be able to use the filter from home, so it's a no-go for me.
Just for fun:
. HO - 2½ hours @f/2 - Bortle 4B (mag/arcsec² = 20.60):
Processing:
. Gradient correction - Default settings.
. Color Calibration using a patch from the right edge as background sample.
. BlurX - Correct only.
. StarNet2.
. Unlinked STF.
Off-Topic:
HOO edit from the SV220 HO data:
Narrowband with OSC?
Just curious. Can one shoot narrowband successfully with a OSC? As I think of my next setup, I’m curious about having options to shoot broadband and narrowband.
Tests narrowband filters specifically with OSC cameras, directly relevant.
Oct 5, 2022
SHO type processing with OSC using dual narrowband filters in photoshop?
Has anyone figured out a way to do SHO type processing with OSC using dual narrowband filters in Photoshop? I see a lot of images being posted now with OSC cameras and dual narrowband filters like the L-extreme etc. doing a simulated SHO type color s...
Dual narrowband filter with OSC camera testing relevant to your processing technique inquiry.
Nov 14, 2022
Planetary camera recommendation for pairing with SLOAN/UGRIZ filters
I'm looking into procuring an astro camera (preferably from ZWO because I use an ASIAIR) that has high sensitivity outside the visual spectrum so I can perform tests with SLOAN/UGRIZ filters and maybe some spectroscopy work on the side. I will be...
Tests dual-narrowband filters with OSC cameras; discusses UV/IR filter considerations
Aug 18, 2025
Would you replace the Built in UV/IR cut on a 2600MC with AR glass?
Hello All, I am looking to replace the built in UV/IR cut window on a 2600MC-Pro with AR window and using a better UV/IR cut filter with better cutoffs in the UV and IR (Baader cmos optimized UV/IR cut filter) so i get less UV and IR and better glass...
Discusses replacing UV/IR cut window on OSC camera with external filter
Sep 18, 2025
Dual narrowband imaging issue
I'm new to using dual-narrowband filters in combination with a OSC camera, and I'm faced with the following problem. During one of the last sessions, I used an Antlia ALP-T 3nm Ha-OIII filter with a ToupTek ATR2600C camera. The filter is inst...
Addresses dual-narrowband filter use with OSC cameras; similar setup questions
Aug 6, 2025
