I haven't had time to try it myself but I'm curious, would there be any benefit to running a guide scope with a 2X barlow. In my case, guiding at 800mm verses 400mm. My guide cam pixel size is already rather small at 2.9 microns.
mmmmm, I really can't see a barlow doing any of those things with a point source. I don't have any problems at 2.9mc so I'm not sure that larger pixels would be an advantage. I'm just going to have to give it a try.
=Y2IQFchis tells you that for your focal length and
Leonardo Ruiz:
Hi Tony.
With a focal length of 910 mm, 2.9 microns and a resolution of 0.5 to 0.6" it is perfect, you don't need better guidance.
Let me send you a link that does the calculations for you:
https://astronomy.tools/calculators/ccd_suitability=Y2IQFchis tells you that for your focal length and
This tells you that your pixel size, you need a minimum resolution of 0.66". Since your RMS, which is the resolution you have in the guide, is 0.5 to 0.6" you are fine.
If you would like to work with more guidance margin, instead of increasing the focal length of the guiding tube with a Barlow, I recommend using BIN2x2 or using a focal reducer, which on the other hand will save you a lot of time since you are working with an f/10 focal length. which is very high.
I give you two examples, one using a 0.8x reducer and another with 2x2 BIN.
With a 0.8x reducer, the minimum resolution you should have is 0.82, which gives you more margin for error.
Using the BIN2x2, you have even greater margin, with the minimum resolution being 1.31"/pixel.
Try it.
Rodrigo Flores:Tony Gondola:
I can give you my experience, I have a GSO RC8 and an Ioptron GEM45 + asi294mc pro, due to weight issue I could not fit a 600mm guide tube for guiding and without an OAG it is difficult to guide, but i did the test with my william optic uniguide 50/200mm f4 with a barlow x2 and the asi120mm + uhc filter (because i am in a bortle scale 9 sky), the RC8 is f8 and the guiding was at f8 the same (because of the barlow), in astronomy-tools it gave me a ratio of 1:3.29, in real life, everything worked perfectly, I had visible stars and maintained the usability ratio of the guidance (maximum 1/3 of the focal length of the main) allowed me to play for a long time and did not exceed the 13kg of the mount for proper guidance
Miguel T.:
make stars no longer round & more.
Andrii Aloshyn:Miguel T.:
This is not important for guide scope. Guide software use mathematics to calculate center of the star even if it is nod round/elongated/etc
I use off-axis guider and stars nether round there, because it takes side part of the image from main scope.
