Problem with M54 extender and coma corrector.
2 replies138 views
Raúl M. avatar
I have a TSFMA360 focuser that I want to use with a TS 1.0x coma corrector for Newtonian telescopes, so that the corrector can be screwed into the focuser. I  have an adapter to be able to screw it in.The problem is that, because the drawtube of the focuser is short, I can't reach the focus distance. I tried adding an 8mm M54 extension to the focuser, but it has an internal burr in the threaded part that prevents the coma corrector from sliding through it. I was told that this happens with all extenders. Do you know any M54 extensions without this burr so the corrector can pass through? Is there any other solution besides changing the focuser? Thank you very much for your help.
Raúl.
Raúl M. avatar
I will, thank you!
Custom M54 tilt adapter to suit QHY CFW3M-SR & OAG-M system, fits within 55mm BF - Design Files Included!
Hello all. I have a QHY 294M-Pro, CFW3M-SR, and OAG-M fitted to my Vixen R200SS newt. I have been battling tilt with my 294M ever since I bought it, and have been stumped by the lack of suitable tilt adjusters available on the market (especially in M...
Both posts describe challenges with M54-threaded astronomy equipment that lack readily available or suitable solutions for their specific optical configurations.
Jan 1, 2025
Unable to achieve focus after reflector modifications
So last week I received my new spider, primary mask and rear plate(?) off AliExpress (link for reference - https://www.aliexpre....51d31802lnldIB) for my Sky Watcher Quattro 250P F4 My steps so far as follows: I installed the spider and mounted the s...
Both posts describe mechanical compatibility issues with telescope components that prevent proper assembly or function.
Aug 10, 2025
Custom Newtonian Builders in the US?
Hi, I'd like to build a 10" F3 newtonian with a curved spider, and a Big Paracorr coma corrector for full-frame astrophotography. I want a carbon fiber tube and everything screwed into the focuser (including coma corrector) then OAG then Fil...
Both posts describe challenges in designing a Newtonian telescope setup that incorporates a coma corrector into the focuser assembly.
May 8, 2024
