My first post on Astrobin! I was wondering if others have experience or thoughts that may be helpful.
I have been using the Starsense Autoguider on my Celestron 8SE for a couple of months now. So far it has worked well-ish. For the 8SE, it has a small image circle and I was worried an off-axis guider would not work well.
The guiding graphs on it are typically +/- 0.5 arcseconds. Depending on the target I can often get exposes up to 5 minutes with mediocre looking stars. I have not pushed it past 5 minute exposers.
With a lot of targets, I have to go down to 2 or 3 minute exposures to make the stars not be bean shaped. My conclusion so far is that the issue is mirror flop.
My solution so far has been to shorten exposure time and then add a slew and center command in N.I.N.A. every 30 minutes. That has worked well so far, but I would love to push exposure times up. Processing data from longer exposures just generally seems faster and easier.
Are there any other thoughts on how to improve this?
Thank you!
Thank you!
