N.I.N.A can't find the right rotation during sequence run
1 reply94 views
DavesView avatar
Using framing, I then 'Add target to sequence' and fine tune the sequence. I start the sequence and when it gets to the 'Slew, Center, Rotate' step, it slews, centers and the rotator turns one direction. It takes a snapshot and slews the other direction. It continues this back and forth until I stop it. Any ideas?
Linwood Ferguson avatar
Generally this is a sign that you need to reverse the direction in the driver.  If ASCOM just click on the gear and there should be a flag there, or I think NINA has the same flag exposed on the equipment page.
Be aware if you use PHD2 with the rotator that reversing the flag in ASCOM reverses it there. If PHD2 then doesn't work properly, there's a separate (non-ASCOM) reverse flag on the other equipment page.  Get NINA working first, then test PHD2 by calibrating, rotating 90 degrees, and guiding and if it runs amok flip the flag.
NINA sequencer issues
Hello, I have recently created a sequence with the nina framing tool. Ive saved the sequence for use on multiple nights. When i re load the sequence, the option to center the target and correct the rotation does not work. I just goes straight to guid...
Jun 29, 2023
Both posts describe technical problems with astronomical imaging sequences where the slew and center functions are malfunctioning during automated telescope operations.
Python script to generate target acquisition.csv file from image files in a format suitable for upload using AstroBin's upload csv dialogue
Update 28th October 2024 I have just released the latest version of the script. v1.3.11V1.3.11 changes 1.0 Fixes bug where running the script for the first time from the installation directory would fail 2.0 Deals with the case where the filter names...
Nov 23, 2023
Both posts discuss technical issues and solutions related to astronomy software or equipment automation.
