RC10 Backfocus has moved since mirror cleaning and collimation
5 replies187 views
Tim Ray avatar
Hello eveyone,
I have an Orion Steal Tube RC10 F/8. Last weekend I removed and cleaned the primary mirror. I reinstalled and collimated the mirror and snuck in a quick imaging session on Wednesday.  I have modified the secondary mirror holder and it no longer has the ability to move towards the mirror to change the separation distance between primary and secondary mirror.
Before the cleaning the subs were plate solving at 2035mm of FL. Now the subs are plate solving at 2060mm. The camera does focus further from the rear of the mirror cell. Currently the focus distance is 282mm. I know both of these measurements fall long as they relate to specifications of the OTA. Do I need the increase the separation distance between the two mirrors to decrease the focus point behind the cell and bring the overall focal length closer to the 2000mm spec? I have a good collimation, I would hate to redo it if I don't need to. Is the 2060mm focal length still within the "sweet spot" of these GSO RC optics?…
Thanks for everyone's commits in advance!
CS Tim
If the original position (secondary - primary) was the one to minimize spherical aberration at a given BFL then any change in that distance will result in an increase of said aberration. Do you have a number for the original BFL? Without actual numbers (re: optical layout) is hard to come up with a meaningful number.
Concise
Tim Ray avatar
Andrea,   The spec back focus should be 233mm. It is currently 282mm for a 50mm delta… I was at 240mm before and thought I was close enough. Now with the gap being  50mm instead of 7mm I thought that might be to much.
Hi Tim,
This is what I get with your data before you changed the spacing:
Note that you were a tad slower than nominal @ f/8.14
Now the present situation:
Note the difference in the secondary conic constant b.2. Since this was fixed at the time of building (and figuring the mirrors) it cannot be modified and that change in spacing will result in some (extra) spherical aberration and coma.
N.B.: it was my educated guess that the primary F/# is 2.
Insightful
After performing the calculation that amount of despacing will result in the diameter of the aberrated PSF (100% geometrical energy) to be equal to 10.4", e.g. about 7 pixels with your typical sensor. On Axis. Coma is probably worse.
P.S.: I stand corrected (large secondary, fast system, low sensitivity), coma is only about half as much at 30' from the optical axis.
P.S.S.: I corrected the diameter in pixels as I was given the radius instead (late night…)
Tim Ray avatar
Thanks for the datasheet and calculations. I guess I am moving the main mirror and collimating. Thanks again for the math.
CS Tim
Unable to achieve focus after reflector modifications
So last week I received my new spider, primary mask and rear plate(?) off AliExpress (link for reference - https://www.aliexpre....51d31802lnldIB) for my Sky Watcher Quattro 250P F4 My steps so far as follows: I installed the spider and mounted the s...
Both posts discuss modifications or maintenance work performed on reflector telescope components that affect optical performance or alignment.
Aug 10, 2025
RC8 Collimation using Innovations Foresight SkyWave
Hi, I will soon resume AP using my GSO RC8, that hasn't been used for 2 years and travelled a bit by car in between. Last time I checked it wasn't collimated anymore. I doubt it will be when I'll get it out of retirement (never works that...
Both posts describe issues with collimating Ritchey-Chrétien reflector telescopes after periods of inactivity or maintenance.
Aug 26, 2024
Optimized Newtonian - Is it worth it?
There are a lot of ways I can think of that the current crop of Newtonian Astrographs can be improved. Lets restrict the conversation to apertures between 6 and 10 inches. 1.) Lowering the focal plane relative to the side of the tube (eliminate the f...
Both posts discuss modifications or adjustments to Newtonian reflector telescopes to improve their optical performance and functionality.
Jul 28, 2025
Newt Astigmatism: tilt or secondary mirror?
Hello, I'm struggling to get good star shapes across images from my ONTC 10" F4, specifically around the corners. I tried everything and can't seem to locate/confirm the source of my problems. Some information about the setup: General Se...
Both posts describe optical issues with Newtonian reflector telescopes that arose after or during modifications to the secondary mirror system.
May 24, 2024
