Are There Any Scripts That Work With Lights?
2 replies114 views
Szijártó Áron avatar
Hello and welcome. I'd like to ask everyone here who knows if any other scripts that work with lights besides Seastar Preprocessing. I'm curious about whether other scripts can be used with only lights that Seastar did for Siril.
For example the OSC ones, or are there any Scripts that are working with lights that can be found?
daywalker avatar
Yes.
Siril have scripts for bypassing a particular calibration frame type or doing no calibration at all. Its just as easy to  do it manually with siril by creating a sequence with your lights and then bypassing the calibration step.
There is some great information on sirils webpage for when your just staring out.
I'm not familiar with the seastar but i'm assuming it just spits out normal raw or fits files that can be converted in siril and then processed manually or with one of their scripts.
https://free-astro.org/index.php?title=Siril:scripts#Getting_scripts
Concise
NeilM avatar
here is where you can find additional scripts:
if you want to process the lights with no calibration frames you need:  OSC_Preprocessing_WithoutDBF.ssf
Which EQ wedge is the most Easiest to use With the Seastar?
Hello and welcome! I would like to reach out to everyone who is using the Seastar with either the Skywatcher wedge or the wedge designed specifically for the Seastar, which is planned by ZWO. I'm having trouble setting my Seastar into EQ mode, an...
Jul 2, 2025
Both posts are seeking community advice about using Seastar equipment for astrophotography, with one asking about compatible preprocessing scripts and the other about wedge options for equatorial mounting.
