filter size and impact on vignetting
3 replies126 views
Nick Grundy avatar
Hi all, I've been using my 160ed for some time now with an EFW and 50mm filters. (directly attached, asi2600+EFW) That puts the filters about 20mm away from the sensor. (i think)
in calculating the angle of incidence at the edges, at F3.3, even a 50mm filter can cause vignetting? Is my math correct? (530mm Focal length, F3.3, full frame sensor) A diameter of ~53mm would steer clear of causing vignetting (if that was a size)
Maybe this is obvious to everyone else? i'm sure flats could help correct it, but just wondering if i'm missing something in the math here
CS!
Nick Grundy avatar
sorry, I should have noted that I was looking at this in favor of shifting to a asi6200mm/mc
I used the same calculator and it resulted in a recommendation of 48mm, I just did the math manually though and it seemed larger.
Here's where I was coming from. This is wrong?
Are you using AI (tan(arctan(theta)) = theta = 1/(2*F/#))? The (mine) manual calculation gives 49 mm. I guess the difference is in what is that is assumed to be be the light cone angle. This is however purely academic as a standard 2" filter is significantly smaller than that, usually between 44 and 45 mm, mounted. You want 50mm unmounted filters for that sensor and scope combination.
TSA-120 and Full Frame sensor
Hello All, I've been looking at the TSA-120 a lot to use primarily for DSO imaging. As far as I can tell it will cover a full frame camera (using ASI6200MM) without some vignetting. Can anyone tell me what their experience has been or if there...
Filter size and vignetting directly relevant to author's full frame sensor coverage concerns.
Mar 12, 2023
FSQ-85 .73x +full frame
Howdy all. Could someone shed some light on the image quality of this combination, Takahashi FSQ-85 with .73 reducer and a full frame camera? This would be a good angle of view for large subject matter like Rho Ophiuchus. Thanks, Dan
Discusses filter vignetting effects relevant to FSQ-85 full frame imaging setup.
Mar 1, 2023
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
Discusses ASI2600MC camera issues; author uses same camera model.
Nov 27, 2025
Sky Rover 50 SAW review
I have been searching for a telescope with the shortest focal length, the largest aperture possible, and which would work with a full-frame sensor. My first one was RedCat51, which was quite OK, but I wanted something shorter. I found Askar ACL200, w...
Reviews wide-aperture telescope for full-frame sensor; directly relevant to author's setup.
Feb 10, 2026
