Failure to register and integrate an Oiii dataset
5 replies128 views
vikas chander avatar
Hello to all AstroBinners
I need your help!
i have been trying to register and the integrate a set of 100 Oiii subs but WBPP fails to do it as does the stand alone processes
i was wondering if anyone out there is able to achieve integration
the calibrated data can be downloaded from this link ...Helix Oiii CDK 600
thanks in advance to those who try....
best
vikas chander
JB Auroux avatar
Hi Vikas,
I'm going to try… smile
jb
OKay guys, i figured out the issue. Not apparent immedaitley but the dtatset is out of focus and that is why it is not registering and integrating. Please dont waste your time with the data and apologies for the post. I wud have deleted it but dont know how to !! apologies …vikas
JB Auroux avatar
Vikas,
I made the registration and stack with classical parameters.
It looks pretty good IMO.
I send you a wetransfer link via MP.
JB
Hi, That looks good. can u tell me what setting u used and if it was WBPP or seperate processes ? thanks!
JB Auroux avatar
vikas chander:
I used APP... ;)
No problem during registration or integration for any image ; I used the recommended settings for registration, local normalization and integration (with LMC 1/3).
I can integrate it with more specific settings if you wish, but I made a try after a crop with GradX and BXT, and the result seems very nice to me (signal is incredible and also very nice details in it :
(linear image).
JB
First Time Processing SHO with APP (M31) Help Please!
Hi, I have roughly 34 hours of integration time on M31, but when I get to the point of "combine RGB" in APP, things are turning out very green and I am stuck not knowing how best to proceed. I think I have some decent data here but need a l...
OIII dataset registration/integration problems relate to color channel processing difficulties.
Oct 2, 2022
WBPP experiencing "Unknown exception" errors during "Measurements"
I have been having issues with Pixinsight WBPP failing to measure a significant number of sub-exposures during the Measurements step with the reason as “Unknown exception. I have posted this issue to the PI forum and this time been told to use FBPP b...
WBPP failing during processing; directly addresses author's integration failure issue.
Sep 28, 2025
