Use of Virtual Moon Atlas software
4 replies108 views
Gary Warnes avatar
Having downloaded this software I have made use a lot of the functions it performs, including identifying various craters etc. But there is little information on the website and none that I can find via Google about how load your lunar images into the software so that you can make use of the great database the software has. I have loaded an image onto the database but cannot work out how open the image in the software so that it will label your image with the topographic information. I have notice in a few U-Tube videos that images have been loaded into this software to do this but they have not mentioned how this is done. It would be great if anyone knew which part of the software  carried out image analysis of images loaded into the software.
Gary, UK
Have you read the manual? There seems a way to create your own library of images.
Gary Warnes avatar
Hi Andrea, Yes I did read the manual as I did manage to load an image onto the database after reading the manual but then could not find  how to load the image into the software or even what section of the software to use. There seems to be little info about other sections of the software other than the basic setup, should have another look but it was not obvious where to look at the manual. Have you had any luck with this part of the software?
Best Regards
Gary
Not that I have used it personally but I thought this would offer that possibility (specifically Libraries>Setup):
https://www.ap-i.net/avldoc8/FR_Doc_PhotLun.pdf
Gary Warnes avatar
Hi Andrea, thanks for the tip,  I think that is where I put the image file but ill check it out again. This where I got stuck on how to access the file in the software just could not find an open file option. I'll have another look at the software again
regards
Gary
Pegasus Issues of Late
Recently, I updated the software on my PPBA Gen2s to version 2.8.4693.435 of Unity. I immediately started having issues with the devices connected to the USB2 ports. They would just randomly disconnect during the night. Sometimes it happened after fi...
Both posts describe technical problems with software where the user is unable to get expected functionality to work properly despite having the tools available.
Jun 8, 2025
How bad is over-sampling?
Matching pixel-size to focal length sounds great, but in reality most modern CMOS cameras have pixels of 3.8 micron (few exceptions). So most of us with a long focal-length of around 2m and more (SCT's, RC's, CDK's etc.) will have highly ...
Both posts seek practical guidance on technical workflows for processing astronomical imaging data.
Sep 19, 2024
Help with Coma Corrector Backspacing
Hello, I recently finally purchased a coma corrector for my 6" f/5 Newtonian and I am having some serious difficulty getting the backspacing correct. Everywhere seems to say 55mm is the most common, but I have seen in a couple places that 75mm m...
Both posts describe users struggling to find technical specifications or instructional information needed to properly use their astronomy equipment or software.
Jul 9, 2024
Digital Loggers Web Switch and Obs Automation
A recent forum posting noted that the standard device for controlling power in a remote observatory is the Digital Loggers Web Power Switch. I’ve now installed one in my remote observatory (only 10 miles from home.) It works very well. I control it m...
Both posts describe users seeking guidance on how to integrate specific software or hardware tools with their astronomy equipment or workflows.
Apr 15, 2024
