Anomaly in the Lagoon Nebula
3 replies279 views
deleted avatar
I need help identifying an anomaly in one of my Lagoon Nebula subs.  There appears to be what looks like a star but it is definitely not because it does not exist in any other sub from the same session.  No streaks, no periodic lights like that from a satellite.  No trails.  Just this blob with a slight flare.  Any ideas?
Jure Menart avatar
It seems you got something similar I got few weeks ago smile
Check out my post:
https://www.astrobin.com/forum/c/astrophotography/deep-sky/weird-star-on-only-1-5-min-ha-acquisition/
Andrew Murrell avatar
There are a couple of possibilities. Point Meteor is the most likely due to the slight flare on either side. Another could be a cosmic ray interacting with your camera.
it also could be a specular reflection from a satellite or bit of space junk. I've seen this happen visually with the ISS, a flat panel get oriented just right and it's like a flash bulb going off. I can see something that's small enough not to leave a trail doing this. In fact, I think this is much more likely than a meteor coming right at you. There's a lot of stuff up there.
Odd "circle" in imagery when taking photos
Hi all, Starting with: This is a 12” newtonian (1200mm), with a Poseidon-M connected to 50mm (round) filters and an OAG-MAX (with a coma corrector) - 56mm back focus So I’ve been banging my head against a wall trying to figure out what this is… I fir...
Circular artifacts in imagery could explain the blob anomaly in your subs.
Mar 13, 2026
Strange persistent structure/artifact in old (2025) subs — what could it be?
Hi everyone, Quick (and kind of funny) question. I revisited some March 2025 data of the Dolphin Head Nebula—only 13 × 180s frames. A few days ago I resumed the project and decided to register/align those 2025 subs to my new 2026 data so I could comp...
Discusses persistent unexplained structures in subs; directly relevant to your anomaly.
Jan 24, 2026
What's this?
The is a crop from a 170 min. integration of 60 sec subs. 585mono, Ha 6nm, simple histogram stretch. I only see this around very brightest stars in the image. It looks like diffraction rings from the star but I'm not sure. Any ideas?
Addresses mysterious artifacts appearing only in brightest star regions of images.
Jul 31, 2025
