ZWO ASI294MM vs other imx294 astro cameras
4 replies188 views
Jackson Datkuliak avatar
Hi all, I currently have a ASI1600MM, but would like to upgrade the camera while keeping my 1.25” filters. I have heard the ZWO ASI294 has a lot of issues with calibration and software bugs, so I would like to dodge that. That basically leaves other camera manufacturers IMX294 equivalents. Does anyone have experience using the other cameras? One is the Player One Artemis-M Pro, another the Touptek ATR3CMOS10300KMA. Would be leaning toward the Touptek currently as it has the full usb hub in the back
I might be wrong but I was under the impression that the problems with the 294 are more to do with the chip than the manufacturer. If that's the case, you'll have the same issues no matter who makes the camera?
Lasse Skov avatar
Yeah, I agree with Tony. I own a ZWO ASI294MM and I have no software issues. I take 8 sec flats which removes the kinda odd kink the chip has, when taking short flats (under 2 secs in my experience). I can't speak to other brands but the flat issue comes from the chip - not the brand of the camera-casing.
The Artemis-M Pro comes with a tilt plate which is a plus. The ZWO does not.
Also if you use an OAG the Artemis-M Pro can be directly screwed to the filter-wheel which makes the the OAG and camera permanently aligned which is nice (if you attach the OAG to the filter wheel as well).
I have both MM and MC and I had and have ZERO issues with calibrations. This said I'd probably go with the Artemis series if I had to buy again with its built-in tilt plate which is actually useable unlike ZWO's.
Christian Großmann avatar
I own the ZWO ASI294MM and the QHY 294M Pro. Both have their pros and cons. The cooler of the ZWO is better, but I didn't like the dessicant tablets inside the sensor chamber. The QHY version does not cool as good as the ZWO, but the dessicant container that can be screwed on is a huge benefit in my opinion. Otherwise, I do not have any issues with both of them. I do regular calibration frames and although they're not as smooth as on newer sensors, they work just like any other thing I own. I really can't tell any difference.
Upgraded quickly - sell or have two rigs?
TL;DR: Upgraded quickly after getting my first rig and now have two fully functional rigs. Sell the first rig or have two rigs? I got bitten by the astrophotography bug pretty hard. After initially buying a Dwarf3 for my son in July, I bought my firs...
Author considering upgrading camera; post discusses having multiple rigs.
Dec 8, 2025
Mono camera advice: 2600mm vs 6200mm for bortle 8+ astrophotography
I currently have a 2600mc that Ive been using for a little over 3 years and need some camera advice for a possible mono setup. I live in bortle 8+ and only get to dark sky once a month or so. I’m more into clusters and galaxies than nebula, but I end...
Discusses mono camera options and upgrades for astrophotography imaging.
Dec 7, 2025
