Celestron2 avatar
I have been taking photos of nebulae and galaxies for the past few years and am now wondering what my next steps should be. I currently use a Celestron Nexstar Evolution 6 SCT on an AVX mount and a 60mm guidescope for autiguiding. I have stuck with the DSLR route thus far (due to my limited budget as a university student and the large focal length of my telescope) and currently have a modified Canon EOS 600D.
I have attached my best images to date below. What could I change/upgrade to improve these? I can't remember exactly how much exposure time went into each but it was at least 2hrs at IOS1600 for both.
I have been considering changing the telescope for a while but am not sure if it is the main limitation in my setup. Is this something I should be looking into further?
David Redwine avatar
Your next step should be to post your work.  Without that you aren't going to get the comments and suggestions you need to make progress.
WRT the two photos you have posted, both  can be significantly improved using curves.  Open the curves function of your processing software, place points at the right and left side to "pin"  the black level and the white level  then pull the middle of the curve up to enhance the color and contrast of your image.  Don't over do it.
Well Written Helpful
I think the main limitation is the imager not the scope. I and many others have done creditable work on similar scopes so this is definitely not a bar. I'd suggest you consider a cooled OSC camera for a replacement of the 600D. This said I can see you would do well to improve upon your processing skills as others have posted. This is a never ending quest and we all began way down that particular ladder.
Helpful Insightful Respectful Supportive
Gary JONES avatar
Hi Celestron 2 (sorry I dont know your real name),
I'm relatively new to astrophotography too - I started about a year ago, and been on the same journey as you, so hope I can help by sharing my recent experience.
My first comment is that if you can produce images like the one you've posted above of the of M51 (the Whirlpool Galaxy) and M51b (aka NGC-5195), then you do not need better equipment - that is a fabulous image. Both images have nice round stars, so your tracking/guiding is good, and your exposures are good, particularly if these are single exposures.
The EOS 600D is 18Mpx - which is fairly high resolution - actually better than the ZWO astro camera I'm using.
When you say 'modified' - what modifications have you done - presumably something to do with filtering ?
I'd echo David's comment above - post some images on your public page, and invite constructive comments on ways to improve them. Photography is a subjective art, so you're bound to get differences in opinion, but there are thousands of members on AstroBin who have been doing this for a long time and are willing to offer helpful advice. If you've been enjoying this hobby for a few years, then I'm sure you have other images as good as the ones you've posted above. It doesn't even matter if the images are terrible - post them and ask for feedback, then revise the image and ask again
My advice is this - keep using your current equipment, and spend some time learning to improve the images you already have.
I've spent the last month going over my old images and learning how to bring out detail I never knew was there.
This image of the Helix Nebula was one of the first astro-images I took - I was amazed that I got an image at all and immensely proud of it.
As I experimented more with post-processing, I realised there was a lot of room for improvement, and was able to bring out more detail and character in this revised image - although I think it's too 'soft' now, so I haven't finished with it yet.
As you probably already know, AstroBin encourages users to post updates to their images, so 'tinkering' is definitely expected and encouraged.
If you're on a budget, I highly recommend you invest in Affinity Photo to process your images.
I've spent a lot of time trying to use Photoshop and experimenting with other apps, but found the workflow very tedious and frustrating.
At about USD 65, Affinity Photo is a fraction of the price of the other packages, with no annual license fee.
It can stack/ align RAW images and includes post-processing tools specifically designed for astrophotography.
It's also cross-platform, and comes with a free trial.
You will get a lot more mileage out of your existing camera if you master post-processing.
As David and Andrea have suggested, try experimenting with curves, gamma, black point and white point, as well as the noise reduction and clarification tools. You'll be surprised how much your existing images can be improved.
As for your images above :-
- if these are both single exposures (as opposed to stacked images), then your guiding/tracking is fantastic.
- Using a high ISO will introduce more noise - try experimenting with a lower ISO and longer exposures.
- Invest in some stacking software - this allows you to take many images of shorter duration and average them out to reduce the negative effects of imperfect tracking and sensor noise.
- The Whirlpool galaxy is a very nice image. The stars have a natural colour and the dynamic range of the galaxies is good too.
Some of the stars are a little elongated which means your polar alignment/tracking is not 100%, but this can be eliminated by stacking images.
Some of the brighter stars appear a bit bloated, but I think this is due to a bit too much contrast in post-processing, rather than something in the original image. Try experimenting with noise reduction, clarity and saturation to enhance the nebulosity of the galaxies - use this for inspiration, as well as images of the same target posted by others on AstroBin.
- The Wizard's Nebula (NGC-7380) appears to have a good dynamic range, the background stars are nice and round.
Try enhancing the nebula itself - experiment with 'backing off' the background stars so they don't dominate the image, and lower contrast to reduce bloating in the brighter stars. The image also looks to have a colour gradient running diagonally from top left to bottom right - which you can compensate for using the gradient tools in Affinity. Also try to enhance the nebula by experimenting with curves, saturation and masking.
As Andrea rightly says, this is a never-ending quest - but mastering the art of post-processing is likely to get you much more mileage than new equipment.
I hope that helps - and I'll look forward to seeing the images above on your public page soon - and hopefully many more after that
Gary
Lynn K avatar
First of all, your image of M51 looks very nice for a C6.  I'm not sure what the nebula is or how faint of an object it is.
I am not new to astrophoto. I have been imaging since 2005. BUT, I know little about the new Chinese CMOS cameras and have done very little work with DSLRs.  I do have a modified Canon T3.  I started CCD mono and do mostly CCD narrow band imaging.
You question is very general and difficult to answer.  I assume your budget as a college student is limited, and so suggesting equipment improvement is limited to how much.  100 or a 1000 dollars/euros???  The standard equipment move to improve  data is usually moving to a dedicated CCD/CMOS camera, but a cheap model may not show much improvement and a better cooled model may be beyond your budget.  The other standard suggestion is the mount, but I personally think the AVX is find for a C6.  A new mount would be more a long term investment in planning for more sophisticated equipment.  AND Again, that is more likely way beyond your budget.
SO, a question that can be more easily answered is, for X amount funds is it best to invest in a Scope (apo refractor), dictated CMOS camera or software?   OR none, and work with what I have?
Your sky is you most limiting factor.  How are you skies??  How portable do you have to be??  Being a student, how much time can you give to acquisition time?  It 2 hours your limit.   What is your computing/software capabilities? These factors limit your imaging ability and play an important roll in how effectively any equipment can be applied.
All astrophotography goes through two phases.  Acquisition and processing.  You are asking primarily about acquisition, but a number of the suggestion are recommending better processing.
Sorry for the rant, it's a drawback of the trade.  I'm an x-prof.
Lynn K.
Gary JONES avatar
Hi Celestron 2,
Another thought to add to Lynn K's comments …
I have a ZWO (Chinese) ASI-071MC Pro single-shot colour camera. Its very easy to use and includes things like sensor cooling, anti-dew and other bells & whistles.
But - I also have a nice DSLR, along with the appropriate adaptors, which produces equally good images on my telescope.
The main reason I bought the AS-071 was so I could leave it permanently bolted to my APO refractor, and grab my DSLR anytime I needed it, without the fiddling of swapping things around.
My personal experience is that I still have a lot to learn about acquisition, and have a loooong way to go before I can justify the expense of better equipment.
BUT - I've spent a lot of time learning about post-processing, which has improved my images immensely.
One thing about a dedicated Astro camera is that it will likely store images as FITS files, which encapsulates a lot of astronomical information like RA/DEC etc into the image. So - you will need software that can read FITS files, and I highly recommend getting something that also does stacking and post-processing.
IMHO - the best investment you can make is to spend $100 on something like Affinity Photo, experiment with optimising your existing images,
and keep posting then on AstroBin for feedback.
Gary
Bruce Donzanti avatar
I primarily use a Celestron C11" EDgeHD to image but SCTs like mine and your C6 are not the easiest way to start learning AP.  However, you are off to a decent start.  Given your limited budget, I think you have two options:
1- stick with what you have and keep improving your processing skills (lots of free videos to do this for programs like Astro Pixel Processor and Pixinsight).  Make sure the scope is well collimated and your guiding is good (I assume you are using PHD2 to guide).
2- if you want to get a new scope, find a used 80mm Apo refractor (triplet preferred but doublet will work if limited budget) which will work nicely on your AVX mount and your guide scope.  This type and size scope is the easiest way to learn and enjoy the hobby.... way simpler than the SCT.
Helpful Respectful
Jonathan Piques avatar
First of all, great job on what you’ve done to date with what you have: well done.
Secondly, if you’re looking to up your game, I have a few suggestions:
1) Get more integration time. 2 hours isn’t a ton of time, especially with an SCT and a DSLR like you have. Experiment: try 4, 6, 8 hours or more, even over multiple nights. At some point you’ll reach diminishing returns on additional integration time, but if you’re just around 2 hours now I guarantee more time will lead to noticeably better images.
2) You didn’t mention processing: make sure you are calibrating everything properly with flats, darks, and bias.
3) Don’t mess with a new scope or mount or camera yet. You don’t need it: you can improve with the equipment you have.
4) On the topic of processing, use the best software you can afford.  IF you can save up for it, I highly recommend Pixinsight. It’s really the best out there and it WILL make a difference in your final images. And it’s not as hard as you might think to learn: trust me. If not, there are many choices out there. My main point is to use the best software you can afford and really learn how to get the best out of it. Just looking at your images, which are a great start just to re-iterate, I guarantee you can get better results by focusing learning to make the most of a software platform. YouTube tutorials and other online forums can help a ton in this respect.
Keep at it man! You’re doing awesome. Hope this helps a bit.
Gary JONES avatar
Hi Celestron 2,
I agree 100% with Bruce and Jonathan.
IMHO you don't need better equipment.
If you're getting results like the images above using your existing gear, then you're already a long way up the learning curve.
A largish SCT is a lot more difficult to use than a small refractor, so keep doing what you're doing in terms of acquisition.
As I mentioned in my earlier post and as Jonathan suggested, longer integration times will definitely give you better images.
From your original post, I got the impression that your images were single, 2hr exposures - which means your PA and tracking were spot on.
But it also means your images will be less tolerant of small errors in PA and tracking, risking disappointing or unusable images with longer exposures.
The best way to increase integration time is to take lots of shorter images and stack them using astro-stacking software.
If you haven't used stacking software before (not certain - maybe you have), then try one to get some practice.
Pick one or two fairly bright targets, and run a couple of sessions using (say) 30 x 180s exposures.
Then stack them to adjust for any alignment errors, and experiment with normalisation, noise reduction, saturation and clarity etc.
I've used PixInsight and Astro Pixel Processor - they both do an amazing job.
I found the learning curves a bit steep, and APP is a bit lacking when it comes to documentation.
But both are available as free trial, so I suggest you give them a try.
If you don't already use darks, flats and bias frames, learn what these mean and include them in your workflow.
You can still get good results without them if you post-process your images well, but using them will make a huge difference to your final images.
Personally, I recommend Affinity Photo - that's all I use now.
It's not as feature-rich as APP or PIS, but it's very inexpensive and easy to learn (particularly if you already use Photoshop), comes with a free trial, good documentation and lots of training videos you can access from inside the app. It manages darks, flats and bias frames, and includes photo editing features and filters specifically for processing astronomy images. It is also cross-platform, so available for Mac or Windows. I suggest you give this a try, then decide whether you can benefit from the extra features in a more powerful product, and which one is best for your budget.
And post your images on your public page so we can all see them smile
Gary
Celestron2 avatar
Thank you very much for your comments. The images are both stacked using DeepSkyStacker (apologies I didn’t word that very well).  I used 180/300 second exposures, I can’t remember which (it may have been different for the two images).
I’ll have a look at Affinity photo, I’ve been using photoshop thus far and am starting to get to grips with it but it does cost a bit per month.
Regarding the camera, I have been considering an OSC cooled camera but have held off due to the cost. A cooled camera with an equivalent sensor to the Canon EOS600D I currently use is a bit out of my price range at the moment. My other concern is that the less expensive ones have smaller sensors which could make life significantly harder with the 945mm focal length I’m dealing with (the focal length is with an f6.3 reducer/Flattener).
I haven’t got that much to post at the moment as I haven’t been able to get the telescope out much recently due to bad weather and warm/light summer nights. I’ll have a go though.
Gary JONES avatar
Hi Celestron 2,
OK - that helps to round out the background a bit.
I've used Photoshop for 20+ years, but refuse to pay a recurring fee that is too much for what I need, and where the app no longer works at the end of the subscription.
Affinity is very similar tp PS in terms of the tools and workflows - and costs less than 3 month of PS and you own the license software for ever.
But I think the overall comments are the same - get the most out of post-processing before you invest in more equipment smile
Put the images you posted above on your public page - they are good images, and hopefully you'll be motivated even more by positive feedback and advice smile
Gary
Dale Penkala avatar
1st very nice photos and keep up the good work!
2nd, Post Processing,
3rd, Post Processing,
lastly, Post Processing!
There is a TON of excellent suggestions that has been stated and probably the one that @andrea tasselli along with several here have stated is processing your images! I’ve learn here on AB myself that post processing is key to making your images presentable. I’ve had images that I’ve taken a while back that were just ok and with the new software and processing techniques made them into literally different images!
My best example would be the Cocoon Nebula:
1st time I processed it I was ok happy with it. https://www.astrobin.com/t2jya2/
But I just recently reprocessed it in APP and came up with this now. https://www.astrobin.com/pw48gv/
2 completely different images. And here is the thing, while I’m really happy with it now, I know if I gave it to any number of imagers here on AB they could make it way better then my best attempt. Point is post processing is KEY to creating a beautiful image.
Your equipment, Nothing wrong with it for now. I think the AVX is a great little mount capable of “WOW” images with the right setup. Your SCT may not be optimal but it is teaching you a lot about autoguiding (because of the longer fl) and image scale! If you get good results with that for tracking, you will have even better results when you do an imaging newt or ST80ed (as some have mentioned) on that mount.
IMHO, (and thats all this is) look at your post processing and software! Personally processing software can be worth MORE than any other piece of equipment you can buy for now. If there was only 1 other thing I would buy or upgrade to other than the software/processing skills would be a good OSC CMOS camera. I’m personally a big fan of the ZWO brand.
Again keep up the great work, and best of luck! Keep posting on AB! I’ve found this site to be so much friendlier than so many other site and the people here are wonderful at helping others and sharing there thoughts and ideas!
Dale
Bob Lockwood avatar
I think to your work this far is pretty good, processing images has a major learning curve pending what software you use. But for equipment being used, I think for now the scope and mount will work well for you so long as you keep the exposures short. As for the camera, it’s a matter of you budget as you stated. A lot of good work coming out of DSLR’s but if your wanting to go with an astro-specific OSC or Mono camera, it’s pretty much going to be your budget. Set your max price, do your homework, and get the best camera setup you can afford at this time an go from there as time goes on.
Greg McCall avatar
I would be thinking about more imaging time at night and calibration in the daytime without impacting data colection.
My suggestion is to invest in a cooled astro camera.
This allows you to take images at a set temperature and mimic that temperature in the day time for calibration images.
i.e. You can then take say 25 darks inside, at home, during the day, away from dark site for example, just by setting the camera at the same temperature (bin, offset & exposure time) as the lights were taken
Next, a light panel for flats. Again, in order to take calibration data outside of your imaging time.
Unfortunately, my two suggestions require a purchase but will give you more time to collect data in a given night and more data results better images because of more signal to drown out the noise (another way of saying better SNR)
Processing improvements will only go so far but data is king.
Gary JONES avatar
Hi Celestron2,
I agree 100% with Greg - there is no substitute for good original data, and a dedicated cooled astronomy camera will give you better data than a cheaper camera.
BUT - whether you get better equipment or more experience processing your images, I think the best approach is to strive for continuous improvement.
I've taken lots of pictures on my DSLR as well as my cooled camera.
In terms of improvement, I progressed a lot more by learning how to process my old images than I did by upgrading to a cooled camera.
You're unlikely to get a better result from a dedicated astronomy camera until you get the best out of your existing equipment.
As an example, here is my first ever astro-image - the Lagoon and Trifid nebulae - I was immensely pleased with this image.
But as I learned more about post-processing, I realised that the colours were clipped and that the image lacked 'nebulosity' - the fine details of light and shadow. If you zoom in on either nebula, you can see it has a 'blotchy'' appearance with patchy colour gradation, and the blue reflection of the Trifid Nebula is over-saturated and a lot of the subtle detail is missing.
After experimenting a lot and getting more experience with post-processing, the image now looks like this.
The colour graduations are much smoother, there is more nebulosity in each nebula, and the blue reflectivity of the Trifid nebula is much clearer and more natural.
Actually, I think there's still room for improvement of this image, and I'll probably return to it one day for another revision, to fine-tune the white balance.
But my point is that the second image came from exactly the same data as the first one - but is a superior image because of better post-processing.
My advice is to get the best out of your existing equipment by becoming an expert at post-processing.
When you reach the point where you can't improve your images any further, then think about getting better equipment.
I hope that helps
Gary
Ferenc Szabo avatar
I'm new to astrophoto, but regarding your first image of the Whirpool galaxy , it's excellent.
The second one , seems to have some background gradient, like either light pollution or the stretching caused some color artifacts.  It happens to me all the time too.
Here is the thing with osc or mono cameras.  They will only complicate things if things aren't already complicated enough.  I have 2 osc cameras, and yet I like my Pentax and Nikon cameras better, because it's just so simple to deal with them.  My issue with them is summer heat and  their noise level due to heat. (Some people will deal with that and make them disappear during post process, like never happened)
So that's my 2 cents, if you ever decide to buy a cooled CMOS astro camera, just remember, you are adding more complications . I've seen /read plenty of people selling their CMOS cameras with the excuse that they just don't want to deal with .fits files  and don't want to deal with 7 different filters and have spent thousands of dollars ,  they want to keep it simple and easy as possible.
Gary JONES avatar
Hi Frank,
Yes, I agree with you 100%.
I think the second image could be 'brought to life' with good post-processing.
And yes, a good OSC camera is nice, and a cooled sensor does reduce noise, but it also adds a lot to your workflow.
Mono cameras and filter wheels and multiple filters are even more expensive and complicated.
My advice to Celestron2 is still the same :-
Keep using your existing equipment, practice and experiment with post-processing, and let us see more of your images on AstroBin smile
Gary
Helpful Respectful Supportive
Celestron2 avatar
Thanks very much for the advice. I have been looking at filters for a while and the Optolong L-eNhance/l-eXtreme seem to be the best options for the DSLR (I'll stick with it for the moment) but I'm not sure which to go for. Any thoughts?
I have Bortle 4 skies according to the Clear Outside app (sky quality of 21.0) if this helps.
I will try an post the images and will keep tweaking the second image to try and bring the nebula a bit better (Affinity photo is definitely something I might try out).
Respectful
Gary JONES avatar
Hi Celestron2
Happy to help -- I hope the advice was useful.
Regarding your DSLR and filters ...
DSLRs usually (almost always) have an IR filter in front of the image sensor.
This is really helpful for terrestrial photography, but attenuates the subtle reds you might see in an emission nebula.
So the first step would be to check whether your camera has an IR filter.
Many serious astrophotographers modify their DSLR to remove the IR filter, and use an external IR filter instead when they do terrestrial work.
Then they leave the filter off when they do astrophotography.
Some cameras have a user-removable IR filter that clips in/out inside the shutter chamber - maybe you are lucky to have one of those
In terms of other filters, I highly recommend the UHC (ultra high contrast) filter from Astronomik.
These are quite expensive, but they are worth every cent.
I cannot stress highly enough the need to avoid cheap (inferior) filters.
Also, make sure the filter you choose covers OIII / Hydrogen beta (470 - 520 nm = blue/green) AND hydrogen alpha (620nm+ = red).
May supposedly 'UHC' filters do not have a passband in the H-alpha region, so they severely attenuate the beautiful reds you want in your images.
This filter will enhance contrast in your images by removing a lot of the light pollution from street/city lights.
I've seen astrophotographers struggle with red-deficient images because their filters did not have a passband for H-alpha.
You can only do so much to 'stretch' colours if they are not captured in your original images.
And please do give Affinity Photo a try - you can download the free trial - Id be very interested to know how well it works for you.
But - you are lucky to have Bortle 4 skies - its 5/6 where I live
Best regards,
Gary
Celestron2 avatar
The camera is astro modified, and I'm fairly sure that the IR filter has been removed. The Optolong L-eNhance filter is tri-band (Ha, H-beta and OIII) and seems to be a little bit cheaper than the Astronomik UHC filter you recommend. Is there a big difference between the two?
Along a totally different train of thought, what do you think about using a Raspberry Pi (Astroberry) for telescope and camera control? I am currently using an ancient windows laptop that still runs Windows Vista and is incompatible with ASCOM so am looking to change this in the near future.
The Optolong is a better filter than the Astronomik UHC (I have the latter and it ain't great but also had used the former) and also cheaper.  The only question really is, with Bortle 4 skies why would you do that? There is also the non-trivial question that with your aperture and focal ratio cutting down photons doesn't seem a wise choice, if you ask me, especially considering the wastage due to OSC technology. If anything, try a less selective filter if you feel you need to be a bit more selective (Optolong L-Pro is a good choice and it is also cheaper and gives you balanced colours).
As for the Astroberry option it works but you must do your homework in integrating the various apps into a proper acquisition work-flow. It is linux, after all.
Helpful Insightful
Gary JONES avatar
Hi Celestron2,
I defer to Andrea's experience as far as the filters go.
Andrea also raises an excellent point about the need for filtering if you have Bortle 2 skies ...
The only suggestion I can make is to experiment
In terms of the AstroBerry, I'm not familiar with it personally, but on their website it does look very impressive.
The only thing I'd recommend is to make sure it includes plate-solving (I think it might do because it seems to support  K-Stars),
and Polar Alignment.
Another alternative is the ASIAir Pro by ZWO - more info here.
I use one of these, it includes most (all ?) of the features I see on the Astroberry website, plus power management,
and is incredibly versatile and easy to use. And its actually based on a raspberry pi too
I'd be very interested to know which way you decide to go.
Regards,
Gary
Celestron2 avatar
I have Bortle 4 skies (but judging by another much darker location I visited in Scotland over the summer which also shows up as Bortle 4, I think where I am is nearer the 5 unfortunately). The filter is basically to help bring out nebulae a bit more in my images and to reduce light pollution a bit, it definitely does show up in my images while processing.
I'm fairly sure that Astroberry does come with plate solving software (from what I have seen) and it seems a fairly cost effective method of controlling the camera/telescope, i'll have a look at the ASIAir Pro as well though.
Gary JONES avatar
Hi Celestron2,
In terms of filters …
The Astromonik UHC filter is optimized for f/4+, it has essentially no loss within the passbands unless you have f2 or less.
You mentioned your DSLR has been astro-modified - in that case the Astronomik UHC will give you near perfect colour balance.
In any case, I suggest you buy the best filter you can afford, it will definitely make a difference.
Once you get your filter, try capturing images using identical settings, with/without the filter, then use a photometry tool to examine your images. Most software can display RGB values per pixel - that will help you see the effect the filter has on your images.
Good luck smile
​​​​​​​Gary
Gary JONES avatar
Oh - and please post some of your images smile
Next Scope?
Hey there, I currently shoot with a ZenithStar 73 on a heq5pro but am longing for a deeper focal length… What do you think is a next good step? I have been considering the Explorer Scientific 152 or even the edgehd telescopes. I know I’d likely...
Discusses next steps in astrophotography setup, similar equipment upgrade considerations.
Jul 4, 2020
Hello from Los Angeles
Hi Everyone! I'm new to astrophotography (only been doing it for a few months) but I'm fairly experienced with visual astronomy and did some work in radio astronomy for a couple years. I got into astrophotography when I got asked to teach a c...
Advanced setup guidance for progressing beyond beginner astrophotography stage.
Apr 16, 2020
