Having Trouble With Leveling. What Leveler Adjuster You Guys Suggest For Seastar?
1 reply99 views
Szijártó Áron avatar
Hello and welcome id like to ask everyone who using seastar with leveler Adjuster. Since im started to use the device im kinda having trouble with Leveling while there some stuff i want to capture with it in the right time. Are there any fine leveler Adjuster i can buy for the seastar and of course it is cheap enough to get. Im  basiclly in  a place where the ground or the surface of a object is not really helping to level my seastar, does anyone can suggest any leveler Adjuster? Thank you.
peng155 avatar
Szijártó Áron:
Hello and welcome id like to ask everyone who using seastar with leveler Adjuster. Since im started to use the device im kinda having trouble with Leveling while there some stuff i want to capture with it in the right time. Are there any fine leveler Adjuster i can buy for the seastar and of course it is cheap enough to get. Im  basiclly in  a place where the ground or the surface of an object is not really helping to level my seastar, does anyone can suggest any leveler Adjuster? Thank you.
A good tripod lever will run about $35-$40USD on Amazon.... Search on Amazon for  "neewer tripod leveling base"  The one I brought was the Aircraft Grade Aluminum Alloy 3 Axis Tri Wheel Head, It worked pretty good for me
Is It Possible To Take Calibration Frames With Seastar?
Hello and welcome. I'd like to ask everyone who is using Seastar or knows some method if it's possible to do with Seastar? To take any Calibration frames besides lights. Like darks, flats and biases. I'm just curious that is why I'm a...
Sep 20, 2024
Both posts are from newcomers seeking advice about using Seastar equipment for astrophotography purposes.
Does Seastar Really Have Mosaic Mode?
Hello and welcome id like to ask everyone who uses seastar or really know that mosaic mode really exsist? Does seastar really have a mosaic mode? I seen people are talking about some kind of mosaic mode that seastar have. Some says its can be found i...
Nov 16, 2024
Both posts are from users seeking technical help and clarification about specific features and accessories for the SeaStar astronomy equipment.
Seastar Stacked Images VS Manually Stacked Images? Which Would Look Better?
Hello and welcome, id like to ask everyone who is using Seastar and stacked their Images with both method, with seastar and with Siril software. Just expericed its deep sky stacking menu. And it rised me some queations. If u restack those images that...
Sep 1, 2024
Both posts are from users seeking advice about optimizing their Seastar telescope equipment for better astrophotography results.
How Does Seastar's New Flats Work?
Hello and welcome, I'd like to ask everyone who is using Seastar and has taken flats with it or has experience, how does this work? I recently managed to do the flat shots with my Seastar, but there's one thing I don't know about this. Li...
Jul 28, 2025
Both posts are from newcomers to the Seastar astronomy equipment seeking practical advice from experienced users about specific technical aspects of using the device.
