Hello Folks,
I'm not quite at ends-wit yet, but close... I'm trying to install StarNet2 into PixInsight, I'm using a trial version of PixInsight, which should be the same as a regular purchased copy for the 45 day trial... The program seems to have installed fine, and I was following a beginners tutorial on PixInsight that has me using the StarNet star removal routine....
Specifics:
Computer: Mac mini M2
PixInsight Version: 1.8.9-3
StarNet++ download from: starnetastro.com
StarNet Version: StarNet2_MacOS_2.1.0_tf_x64_install.zip (Fresh install)
API Version: 180
1) I unzipped the the download and followed the instructions as follows per the Readme file:
2) Check API version
2) Copied the StarNet2_weights.pb, StarNet2-pxm.dll and tensorflow.dll to the Applications/PixInsight/bin folder
3) Fired up PixInsight, Went to Process/Modulles/Install module
4) The Search directory is pointing to the Applications/PixInsight/bin folder
5) I click on Search, PixInsight comes back with 0 additional modules found
I review the install Notes for Mac OS install on the website, I do:
1) I copy the libtensorflow.2.dylib and libtensorflow_framework.2.dylib into /Applications/PixInsight/PixInsight.app/Contents/Frameworks/
2) I fire up PI and try the Moduele install again, and PI still finds no new modules
I close the program and read the README.txt Troubleshooting portion:
Note 1 - Search PI doesn't find StarNet, checked that StarNet2-pxm.dll is in the bin folder, I have the latest version of PI, and all of the files were copied into the correct folder
Note 2 - Note seeing any error, So I'll assume this doesn't apply to me... yet??
Note 3 - And again I'll assume this note doesn't apply to me
So what am I missing, I'm assuming I'm following the latest install procedure. When I Browse the bin folder in the Install Modules Pop-up, I can see the files I copied into the folder, but they are all Grayed out, When I look at the Managed Modules Pop-up window StarNet even isn't listed..... Thoughts??? Suggestions???
Thanks
Specifics:
API Version: 180
Thanks
