C3 26000 pro backfocus distance?
2 replies78 views
deleted avatar
I have a new C3 260000 pro with a Moravian 9 position filter wheel.
Anyone know the back focus for this combo?
From the manual it should be 47.5 mm or 41 mm (depending I guess on the M68 adapter?) but I need confirmation from other users.
The reason I ask is because I have some star elongation that it’s harder to diagnose.
I eliminated tilt in the imaging train by using only threaded connections, so I need to know the back focus is not the issue.
My imaging train consists of a FT 3.5 focuser, extender, field flattner, extender, FW, camera. All threaded connections
deleted avatar
PS: I received a quick response from Moravian.The new cameras are shipped with the new M68 adapter, so the BFF is 41 mm not 47.5.
This explains my problems.
Mr. Pavel at Moravian Instruments was very helpful!
Well Written Concise
Bob Lockwood avatar
I know you already have the answer, but Moravian shows this on their website with the new 68mm adapter.
ZWO Filter Wheel with 183GT?
Has anyone put a filter wheel in the train with a 183GT (or other ZWO GT cameras with built in filter wheel)? Curious about back focus, etc.
Discusses back focus distance with filter wheel combo, directly relevant concern.
Oct 3, 2022
Backfocus for the Esprit 100 & ASI2600MC
Hello! The Esprit 100 ED manual says that the backfocus, when using the field flattener that comes with the telescope and the ZWO ASI2600MC, should be 63mm. A tech person at Sky Watcher says the backfocus with same setup should be 55mm. The field fla...
Discusses backfocus distance calculations with different camera and accessory combinations.
Nov 23, 2022
