How To Fix The Script Failure In Siril?
6 replies193 views
Szijártó Áron avatar
Hello and welcome. I'd like to ask everyone here who uses Siril to preprocess their astrophotography images. Does anyone come across such script failure that even if i use fits files which the software uses, the software still fails the Script? I even made the right directory for the software to use and got the right preprocessing data since I have a Seastar device. Then, I got this error failure message every time I tried to run the Script. I even tried an alternative solution didn't work. What do I do in this case?
daywalker avatar
iT May be better to copy and paste the error rather than take a photo,so the whole error message can be read.
Which siril script are you using?
You should be using one of the osc scripts,not a mono one..
Concise
Cyril Richard avatar
Szijártó Áron:
Your screenshot is terrible.... Fortunatly, the error is very common. You probably mixed format file (JPG and FITS) in the input folders.
Cyril Richard:
Szijártó Áron:
Hello and welcome. I'd like to ask everyone here who uses Siril to preprocess their astrophotography images. Does anyone come across such script failure that even if I use the files which the software uses, the software still fails the Script? I even made the right directory for the software to use and got the right preprocessing data since I have a Seastar device. Then, I got this error failure message every time I tried to run the Script. I even tried an alternative solution didn't work. What do I do in this case?
Your screenshot is terrible.... Fortunately, the error is very common. You probably mixed format files (JPG and FITS) in the input folders.
 YEAH Lately before I used JPG as well for some reason, I didn't know it just targets one file. Is there a way to prevent this from happening or its like a software issue that the newer version cant recognized the file or WHAT?
It May be better to copy and paste the error rather than take a photo, so the whole error message can be read.
I useing the Seastar Processing script since I have the device and using it.
 But thats what it says.
13:36:07: Filter Pattern: GRBG
13:36:08: Saving FITS: file pp_light_00228.fit, 3 layer (8), 1080x1920 pixels, 32 bits
13:36:13: Reading FITS: file light_00232.fit, 3 layer(s), 1080x1920 pixels, 32 bits
13:36:13: Image #231: number of layers (3) 19 not consistent with sequence (1), aborting
13:36:14: Reading FITS: f1le light_00231.fit, 3 layer(s), 1080x1920 pixels, 32 bits
13:36:14: Image #230: number of layers (3) i9 not consistent with sequence (1), aborting
13:36:14: Sequence processing failed.
13:36:14: Setting CND (Curent ₩orking Directory) To 'E: Vstzo\seastar\M33"
Those are the last messages that happens at the end of the Script. I tried every posibble way to get around it, didnt worked.
So im left disorianteted. Unless if anyone know a method to trick the system or what.
It's not a bug. You should read the tutorial for seestar on the website. It explains everything.
