Solving Issues During Polar Alignment
3 replies110 views
GiffS avatar
Recently I have been having sporadic issues during Polar Alignment in the AA+. It will often see XXX number of stars but fail to solve and move on. If I cancel and retry sometimes it will carry on and sometimes not. Change exposure try again, sometimes it solves and sometimes it will run to the timeout unless I cancel. I have checked, but not replaced the relevant cables, and I and running on mains power. It has gotten to the point a few times where I have to send the AM5 back Home and start again. Anyone else run into this sort of issue?
Thanks.
Niels_L avatar
I might have gotten similar issues sometimes, though mine are related to “failed exposure.” When my PA with the AA+ does not load, and I stop PA, go to preview, try an exposure, it often gives me failed exposure. I think my issue is with not enough power to the camera (I’m using one cheap power adaptor for AA+ and have everything powered through the AA+). I’m waiting for delivery of an additional (higher grade) 12V 5A adaptor to split up the power supply.
perhaps you have the same issue.
Johannes Maximilian Möslein avatar
I'll agree with @Niels_L about the power. My ASIAIR was behaving very weirdly very often, but all problems were solved by upgrading the power input and using separate cables for every device (camera, AIR, etc.) If I ran into a problem like yours, I started checking the power input (12V/5A), and it was always just way lower than recommended. So if there isn't another obvious solution, you should give that a try.
Johannes
GiffS avatar
Thanks for the input. I sort of discounted power issues because I am using ASI’s power supply and feeding it from the house main. I will check the power input and cables again.
ZWO AM5, ASI AIR Plus: Polar Alignment
Just a question: when I'm doing the polar alignment with the AM5 using the ASI AIR plus, using the All Sky procedure, I noted that the AM5 is not tracking. I was thinking that after the third picture and after plate solved the mount should track?...
Polar alignment solving issues with similar mount and software setup.
Jan 19, 2023
ASIAIR Mini and ASI2600MC exposure failures despite troubleshooting attempts
Hello, I have been using the ASIAIR Mini coupled with the ASI2600MC camera. My current set-up has been working flawlessly for a long while. Last night I had a little initial trouble with the start-up, the camera advised an exposure failure while I wa...
Camera exposure issues similar to your sporadic solving failures and timeouts.
Oct 11, 2025
ZWO 2600 MC 2025 Version Troubleshooting - Missing frames and exposure failures
Hello to everybody, I need help to solve a strange problem with my new Zwo ASI 2600 MC Pro. I bought the 2025 camera and when I first tested it I noticed this problem: sometimes it did not save the sub in the memory but the asi air kept saying that i...
ZWO camera exposure failures may relate to your intermittent polar alignment problems.
Dec 1, 2025
