APM 2" Barlow 1.5x
8 replies182 views
eric belanger avatar
Hello . If anyone is using this Product . I need help !
APM 1.5x Barlow telecentric for Visual and astrophotography. I have the backfocus right....(i think) but cant see any stars or trees because i tried during daytime also . The focuser tuber went back and Forth trying to focus but Never saw anything .
Just need help
Are you sure you have enough inward travel to reach focus? Test the barlow with an EP and see whether you can reach focus. If you can and then move in and out of it there should be enough focus travel to reach focus with the camera too.
Oscar H. avatar
IMO
to make sure whether you need inward or outward travel to solve your problem:
I suggest you loosen the thumbscrews on the focuser, remove the 1.5x barlow (with your image train intact), and move your imaging train outwards slowly, even out of your focuser if necessary, to see if anything comes into focus then
if it does, then you need more outward travel to solve your problem, if it doesn't, you need more inward travel
Thanks for the suggestions.
Andrea , what Do you Mean with testing the Barlow with an EP ? What EP stand for ? Thank you
eric belanger:
*An eyepiece. If as I suspect the scope is a SW newton then you might have had one if you bought it new.
Ok …so i just had to Take the coma out by about 2 inches. Now …. it's a very long optical train so i Will have to add a screw to tight the coma well . To avoid flex.
​​​​​​Thanks all smile
Oscar H. avatar
eric belanger:
Ok ...so i just had to Take the coma out by about 2 inches. Now .... it's a very long optical train so i Will have to add a screw to tight the coma well . To avoid flex.
​​​​​​Thanks all
does the 1.5x barlow have any 2" filter thread? if it does, you can try adding an M48 spacer to that so it's more secure in the focuser
Gábor Galambos avatar
In order to get focus, you need to move the APM 2" Barlow 1.5x corrector about 3 cm away from the focuser. I use the APM 2" Barlow 1.5x corrector for Lacerta 200/800 photonewton. For the Lacerta Octo Plus 2 focuser, I use the screw spacer shown in the attached picture (3 pieces, which are 3x12 mm).
Werner Stumpferl avatar
Hi Eric,
as far as I know, the APM has a working distance of 95mm not 105 (source TS) ?
Werner
Day time focusing
So I have my new c9.25 edge mostly set up and ready to go. I am unfortunately stuck with a couple weeks of forced night shift overtime currently. Trying to get ready ahead of a night off. I am just wondering if a c9.25 / reducer / asi2600mc would nee...
Daytime focusing techniques relevant to troubleshooting inability to see objects.
Jul 30, 2025
Focus Issue with OIII filter on edgeHD 8
Hello, I recently acquired a 533 mono camera and have been collecting some test shots weather permitting. I use Zwo Eaf for focusing. With the Luminance filter the focus point was very close to my previous configuration (osc camera + cls filter). Las...
Focus issues with optical systems similar to author's focusing problem.
Aug 12, 2025
Image Train and focus with ADC
Afternoon all. I’m after a bit of help. I am just setting up my first SC type scope (Celestron EdgeHD 8) for planetary. I can get focus with the following image train: OTA>visual back>Camera (ZWO 679MC with UV filter) via nose piece. 📷 IMG_4471...
Focus setup and adjustment procedures for telescope imaging systems.
Oct 11, 2025
Unable to achieve focus after reflector modifications
So last week I received my new spider, primary mask and rear plate(?) off AliExpress (link for reference - https://www.aliexpre....51d31802lnldIB) for my Sky Watcher Quattro 250P F4 My steps so far as follows: I installed the spider and mounted the s...
Troubleshooting focus problems after telescope modifications or adjustments.
Aug 10, 2025
Collimation; "confirm with a star test at night". Wat!
Hi! I just got myself a RC10 Truss (TSRC10T64), and while waiting for the sky to clear (it’ll be weeks!) I’m trying to prepare as much as I can. This is my first reflector, so collimation is of course a hot topic :) Every tutorial I have found ends w...
Collimation and star testing procedures for telescope optical alignment.
Feb 12, 2026
