Star "Ringing" Artifact
14 replies521 views
apennine104 avatar
Hello Astrobin,
I have been working on a new setup, and slowly working through growing pains. The setup is as follows:
  • Stellarvue SVX90T w/Field Flattener>Spacers to achieve proper back focus>Falcon Rotator V2, EFW (36mm Chroma LRGB + 5nm SHO), 2600mm attached directly to EFW
One issue I am noticing is that all medium/bright stars have a "ringing" type artifact as depicted below. I have tried flipping the filter orientation, with no noticeable difference. There is various posts on Cloudy Nights and other forums with this issue or similar and Chroma filters, but no smoking gun solution. I continue to highly suspect the filters, but I am honestly not sure.
Photo link/description:
Top row = Reflective side of filter facing telescope
Bottom row = Reflective side facing camera
Each row arranged L-R-G-B-S-H-O (top row missing S&O)
LRGB = 20x5" stacked images
H = numerous 240" stacked images
S&O = single 240" subs
Other notes:
  • I see the ringing in individual frames and with various exposure lengths as well, not presented here. So, I don't think it's Pixinsight introducing it.
  • Luminance seems ok.
  • While Sadr is presented in most of my examples, it occurs in all medium/bright stars all throughout the FOV.
  • Chroma states filter orientation doesn't matter (but swap if it does).
Does anyone recommend any troubleshooting steps from here? I have e-mailed Chroma, and I am awaiting a response.
Thank you!
Chris
Well Written Helpful Insightful Respectful Engaging
Ah, the Onion Rings effect. Interference driven thingy. Getting other filters would be the easiest path out of it, tbh. Refractors seem mostly affected by this unless very high end so maybe there is a clue somewhere there too…
Bob Lockwood avatar
Get with Stellarvue and send them this pic, I'm sure Vic can tell you what's going on
apennine104 avatar
Ah, the Onion Rings effect. Interference driven thingy. Getting other filters would be the easiest path out of it, tbh. Refractors seem mostly affected by this unless very high end so maybe there is a clue somewhere there too...
I thought the onion ring effect was only related to fast food consumption . Hmm.. your response gave me the idea of maybe undergoing the process of swapping the filters between my two EFWs/setups to see if that "fixes" the problem by just putting them in a different optical setup. I will see what Chroma recommends.
-Chris
apennine104 avatar
Bob Lockwood:
Thanks, I have done that too. They have been great to work with.
Maciej Karcz avatar
I use a SVX102T and also keep getting onion ring stars on all medium/bright stars.
I had some back and forth with Stellarvue and have been troubleshooting this issue for about a year.  I get so few clear nights that it's been slow going to troubleshoot.
Stellarvue has been pretty helpful and the asymmetric onion rings I had initially were due to a backspacing issue, but once that was solved I started getting symmetric onion rings instead.
Initially I thought it was due to their .74 reducer and switched to their flattener but the issue persisted.  I started out with ASI2600MC with Optolong filters and later moved to 2600MM with Antlia 3nm but the issue is still there, so I don't think it's a camera or filter issue.
SVX102T with reducer and 2600MC / Optolong L-Pro, all bright stars had rings: M45
SVX102T with flattener and 2600MM with Antlia 3nm SHO + RGB, see red giant Propus at bottom left: Jellyfish Nebula
My post from 1.5 years ago with mostly asymmetric onion rings: here
Regards,
Maciej
apennine104 avatar
Maciej Karcz:
Regards,
Maciej
Maciej, thank you for your response. I had not seen your post before, even though I did a lot of searching. I also just found this post on Cloudy Nights which seems to be the same problem.
Chroma responded that they think it "may be attributable to multiple reflections between sensor window (or the flattener) and our filters". That seems plausible to me. I also have had a string of bad weather that has made this slow going. I think unless Stellarvue provides a different path, I am going to swap my filters (Chroma for ZWO) and see if the issue remains.
-Chris
Well Written Respectful Concise Supportive
apennine104 avatar
Well, I swapped in the ZWO filters, and the onion stars were not fixed. Similar to @Maciej Karcz's experience.
I don't think the issue is with the 2600MM, since the luminance is fine. I am suspecting something with the telescope. I am waiting for more info from Stellarvue. Please let me know if anyone has further thoughts/info!
20x5" per filter L-R-G-B:
Thank you!
-Chris
TiffsAndAstro avatar
Is there any option to move filter further from your sensor?
This is prob. way off but the third image from the right really looks like the posterization effect you get when you don't have enough bits to show the full brightness range.
Thank you!
-Chris
Luminance filter isn't an interference filter so that is to be expected. Hard to find the right ones, I'm afraid.
apennine104 avatar
The telescope/flattener is on its way back to Stellarvue. I'll update when I get this solved, thanks everyone!
-Chris
apennine104 avatar
Quick update to close the loop: A new objective lens installed by Stellarvue fixed the "ringing/onion" issue.
Well Written Concise
Maciej Karcz avatar
Thanks for the update @apennine104 .  I may need to do the same with my SVX102T, just not looking forward to the shipping headache..
Did they provide any explanation other than replacing the lens?
How long was the turnaround time?  Did Stellarvue cover shipping?
apennine104 avatar
Maciej Karcz:
Hi Marciej, they did not explain further, only that it would undergo an evaluation at a later time. I'm on the East Coast, so it was about a week each way, then two weeks at their facility. So, about a month. Stellarvue was great to work with, and they covered shipping in my case. I am not sure if shipping was covered because I had ordered so recently, but they definitely made the process painless.
Well Written Helpful Respectful
Unmounted Chroma Filter Orientation
I have recently purchased a set of unmounted Chroma filters. I have been trying to get clear instructions on which side of the filter faces the camera. The manufacturers say it doesn't matter. Cloudy Nights has several long discussions that agree...
Filter orientation directly relevant to author's Chroma filter setup troubleshooting.
Aug 16, 2025
Diagnostic help, please
Hello, I have searched many sites looking for similarities regarding a worsening issue I have been fighting for some time. I hope that posting here and attaching some photos will help with the diagnosis. Essentially, my stacked light frames using the...
Diagnostic help post may address similar optical artifacts and ringing issues.
Oct 19, 2025
Backwards filters? I lost track...
Hi everyone, I'm in a bit of a bind. I own 2" mounted Baader Moon and Skyglow Neodymium and IDAS NBZ filters. I took both filters out of their mounting cells awhile ago and now I need to remount them. But……I cannot figure out whi...
Star "Ringing" Artifact — discusses optical filter setup and imaging artifacts
Oct 14, 2022
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Fan vibration causing star artifacts; similar diagnostic approach to ringing problem.
Nov 18, 2025
What causes these aberrations?
I've been getting these asymmetric aberrations around bright stars on nearly all my images and struggling to find the cause. They are pretty consistent irrespective of the target's position in the sky and filter type (present on each of L-Pro...
Star ringing artifacts in similar equipment setup; optical aberration troubleshooting.
Feb 20, 2023
