I recently did a narrowband imaging project in SHO:
Sh2-86, NGC6823 and NGC6820, >>the lonely pillar of creation<<
While I was preparing the image, I have already noticed some signal in OIII that caught my attention and which I'm currently analyzing right now in more detail.
The following collage shows a cropped section of the final image's narrowband channels.
I'm interested in the indicated OIII patches.
Does somebody know what this is? Is it stars embedded in the nebula and ionizing the oxygen? Are these planetary nebula?
Maybe there are some members here who are also digging a bit deeper into the astrophysics?
In order to get closer to an answer, I did some analysis:
In Ha and SII, the position is identified through stars which aren't (easily) visible in OIII. Instead at their position, I see the diffuse OIII signal.
To see if they are artifacts, I did some checks. The patches are even slightly visible in each sub exposure. I also prepared an OIII stack without clipping to confirm that the data shows actual signal and to show that the star is not removed. The OIII was captured over two consecutive nights.
I've checked the SIMBAD database and could identify the stars through the GAIA EDR3 catalogue. The stars' ids are provided within the image.
For the stars themselves, I could extract following R, G and B magnitudes from the GAIA database (https://gea.esac.esa.int/archive/):
Star, R. mag, G.max, B. mag
2020090592985593344, 11.8, 13.5, 18.5
2020084442592330496, 12.1, 13.7, 18.4
2020038086994047744, 10.9, 12.6, 17.9
These numbers reflect the fact that we cannot see them in OIII.
Through the associated database for the estimated star distances, (Bailer-Jones et al. (2021)), the distances (pc) of these stars are estimated to be
Star, avg. dist, avg. dist - sigma (LCL), adv. dist + sigma (UCL)
2020090592985593344, 5790.0, 3880.7, 8703.1
2020084442592330496, 5408.2, 3636.0, 8203.8
2020038086994047744, 1879.0, 1365.1, 2922.0
The distance estimates show quite significant spread. At least for the last star (2020038086994047744) it seems to be located within the nebula Sh2-86 (dist. approx. 1840pc. source: https://apod.nasa.gov/apod/ap041004.html).
For the more distant stars, it would either mean that the extension of the Sh2-68 nebula is very far, with a possible reach over 2 to 3 kpc. The alternative I see is that they are planetary nebulae.
Feel free to comment!
Clear skies!
Björn
Clear skies!
Björn
