Rodd Dryfoos avatar
I have been trying for a long time to decide which version of my M13 I should call the final.  I have dozens upon dozens of versions beyond what is posted on Astrobin.  I am trying for a realistic look--so not too much saturation, as much resolution as possible.  I would be interested to hear which of these versions is better, and why.  Or what is wrong with both - maybe I have other versions where I did not make the same mistake.   Both images were taken with a C11Edge at F10 (2,800 mm) using unguided 20-sec exposures.  Exposure time is about 4.75 hours about equally split between RGB.   I took these in summer when I only get about 5 hours of imaging time--and I have had very few clear nights over the last 6 months or so.  that is why the total exposure time is not larger.  I admit teh difference is subtle.  Who knows, with your input maybe I have yet to process the best version.  Thanks for looking
Version A
Version B
David Moore avatar
I prefer the lower one as the blues and less so the yellows stand out more particularly in the white core. As you say it is subtle and reminds me a bit of the colour blind tests opticians give. They are lovely and sharp particularly the lower one in the core and I like them both.
On my monitor they both look too bright in the core robbing some colour saturation. Both show a rather distracting background non-uniformity so you may want to look into it. Having to chose I'd go with the first rather than the second.
Ruben Barbosa avatar
Hi Rodd,
Can i do some fast and small changes in your M13?  You know like the background full of stars....
Rodd Dryfoos avatar
Thank you. My sky stinks so the background is as good as I can make it.  As far as brightness, I have versions with flat profiles but globular clusters ARE bright in the core. Most images have no star resolution or colors in the core at all. If you look at a globular cluster in the eyepiece, it will look like these with a glaring core. That is what I am after. Reslistic
Rodd Dryfoos avatar
Ruben Barbosa:
Hi Rodd,
That looks like the globular cluster is smaller.  The little blue center looks funny to me.  I don’t think you have more stars than mine. You just reduced the size of the core brightness
Rodd Dryfoos avatar
that is the way I am leaning as well
Rodd Dryfoos avatar
herr I’d one with a flat profile. I like it, but it lacks the inherent power and brightness of a globular cluster
Rodd Dryfoos avatar
not sure what you mean about you background, really. Looks good to me.  If you visit my page and find this image you can look in full resolution.  The color in the background is balanced and it looks smooth to me. Maybe it’s the faint stars you see?  They are supposed to be there
I suppose it is all in the eye of the beholder. To me this one is way better than any of those before. The problem you have is that it is somewhat lacking context as the field is very restricted so there is no way you can contrast it against the background field. But again, to each his/her own…
Rodd Dryfoos avatar
I suppose it is all in the eye of the beholder. To me this one is way better than any of those before. The problem you have is that it is somewhat lacking context as the field is very restricted so there is no way you can contrast it against the background field. But again, to each his/her own..
you are right. But this image was taken at a focal length of 2800mm with a relatively small sensor. My goal was a close in shot of the cluster, paying homage to Hubble, so a mosaic was not what I wanted to do.  Besides, with the number of clear nights I get, mosaics take forever.  I did this with a wider FOV previously.  This one explores the core
Pondering a New Pursuit
When I look at an image of a distant galaxy, star cluster or nebula, it evokes in me a sense of awe, a sense of mystery and even, in an inexplicable kind of way, a sense of the sacred. Though the incredible images being made by amateur astrophotograp...
Relevant for understanding aesthetic appreciation of deep-sky astrophotography images.
Feb 7, 2023
Mistakes I Make in Learning This Pursuit
Set up tonight, first time in over 3 weeks because rain, more rain, more rain and more rain. Tonight not a cloud in the sky. Decided to image the Heart Nebula at a focal length of 368mm and at f3.6. First time using the reducer and wasn't sure my...
Relevant for learning common processing mistakes in astrophotography workflows.
Jan 18, 2023
The Witch watching Rigel - suggestions?
I am not happy with this result and I think I know why, but could use any criticism. https://www.astrobin.com/0zrmfg/ This is the Witch's Head and includes Rigel. Most of it was shot from a Bortle 7 location, and the resulting stacks had very, ve...
Relevant for seeking criticism and feedback on image processing choices.
Jan 22, 2023
