Can guiding hurt resolution in deep sky images?
4 replies275 views
I am wondering if guiding can sometimes reduce resolution. Seeing is obviously doing that, especially with longer subs but what about guiding. When the guiding software is banging the scope around every few seconds, say to the tune of +/-  1 arc/sec or so. Is that contributing to degradation of image sharpness where you'll get round stars but fine detail is compromised? Like many things in science and engineering, I know the answer will start with "it depends" but I'd like to know what everyone thinks.
In short, no. The supposed "blurring" occurs because you are integrating over longer time than otherwise (although some mount don't do any guiding at all and results suggest there is no differences here). In order to obtain better resolution (other than having a very good seeing) you can integrate over shorter and shorter exposures and cull out the worst results and keep the best. Obviously you take the hit with increased RON.
Low read noise CMOS cameras have certainly made that approach more viable. Spot-on polar alignment, no guiding, 30 sec. subs with culling down to a certain FHWM and roundness limit. The trade off being taking longer to get to a given integration time.
John Hayes avatar
Yes, sometimes it can.  There are multiple components that make up any feedback driven control system.  The most obvious component is the amplitude response of the system.  This requires that an image shift of say 5 arc-seconds is met with an equal shift of 5 arc-seconds by the mount to keep the image centered.  The next component of a control system is the frequency response of the system.  The frequency response relates to how quickly the system can respond to a change.  If the seeing is moving the position of the star at a rate of say 1kHz, most mounts will have a hard time accurately tracking any movement at that rate.  Fortunately atmospheric tilt generally changes at a pretty slow rate.  Finally, the least obvious characteristic of a feedback loop is the phase response and this is where it's very possible for tracking to make things worse.  For example: If the time for the signal from the guide camera to be taken and processed takes half the time (or multiple thereof) of the period of a periodic shift in the guide star, the correction signal will be applied out of phase of the image shift and the result will amplify the image motion on the sensor--rather than reducing it.   I've greatly simplified things here.  Phase shifts in the response can be caused by all sorts of things in the system but it is a very important characteristic of any control system.  Phase errors in tracking systems are often called "chasing the seeing", which often happens when the guide rate is set to be too high relative to how fast the system can respond to changes.  The best way to implement a guiding system is to configure it to compensate for small, slowly changing errors in the system (such as PE errors in the drive) and slowly varying changes in the atmosphere.  The idea is to minimize slowly varying errors while ignoring the high frequency stuff that's pretty hard to correct--at least by using the mount.
BTW, there are devices called, "Active Optics" (in the amateur world), which use a small window to correct image shift at a much higher rate than can be done by the mount.  With the right target and very careful configuration, these things can work to increase the response of a tracking system.
That's the basis of my thinking on this so thanks for fleshing that out. I didn't think about phase relationships though, that makes sense…
New to or Considering Astrophotography/astronomy?
I had posted this with a new image I’d uploaded as a change from the “typical” review of my processing steps/acquisition. A friend/commentor suggested I post in a forum, so this is the result. This is VERY subjective and based entirely on my experien...
Discusses image quality factors relevant to guiding and resolution concerns.
Jul 31, 2025
How do you measure final resolution?
I think we all agree that between the effects of drizzle and all the other image improvement techniques that are commonly used, final star FWHM is a useless measurement of overall resolution. So how do you measure the real resolution of a fully proce...
Directly addresses measuring resolution and star quality metrics like FWHM.
Jul 31, 2025
Canon EF 300mm f/4 L astrophotography comparison: non-IS vs IS version
Hello all, I am excited to share this test report I wanted to make ever since I acquired both lenses, in an effort to help the community. I will also attach it to the thread for easy download. Enjoy your read and I hope this comparison helps you make...
Compares optical stabilization effects on image sharpness in astrophotography.
Feb 3, 2026
Looking for advice on planetary lucky imaging
I'm thinking about doing a bit of planetary lucky imaging and would welcome some advice on the following: * My OTA has a Dawes limit of 0.58 arc secs * What pixel resolution should I aim for in arc secs and what guidelines can you give me? I'...
Discusses resolution factors relevant to optimizing planetary imaging setup.
Oct 8, 2022
