Bandpass shift overlooked on clip in when using lenses?
2 replies61 views
AstRobert avatar
currently i was trying to get a bit into widefield again, but since I spent a lot of time reading into narrowband and how fast scopes benefit less and less (often starting from faster than f4) when filters get tighter, I wonder how this topic was overlooked when e.g. Clip-In filters are used which are perfect for using a fast high quality prime lens with your apsc…
I am planing to use a really sharp 100mm F2.8 lens but also the classic Samyang 135mm f2 are all in the "fast range" of e.g. hyperstar, where everyone would tell you too look out for bandshift issues. But seemingly its not a topic with lenses as there are not "fast" alternatives of clip ins.
So when i plan to use an l-enhance together with an f2 or f2.8 lens… is this actually useless since I will shift my lines (especially Ha as the filter is rather narrow there) out of the band?
Or am i missing something?
And yes yes I know one can and would probably stop down a bit but, thats not the point of fast, sharp prime lenses, is it? ;-)
Cheers, Robert
L-enhance isn't tight enough to be bothered with bandpass shift, even at f/2 and I use it successfully at f/2.8. Prime lens.
Even with a narrow bandpass it might not apply. Camera lenses are very complicated compared to telescopes. It's quite possible that the angle of the light cone is as steep as the F number suggests.
Filters for f2
Any recommendations for filters for fast setups? F2 -f2.8?
Addresses narrowband filters and how fast scopes interact with filter performance.
Feb 22, 2023
Band shift vs more integration time
What would you choose? I have shot an image I’m quite happy with at f/2 and my 7nm Optolong Ha filter. However, I am aware I might have gotten some band shift. I was shooting other things and I didn’t pay attention to the f-stop at the time. Since th...
Discusses narrowband filter usage and integration time trade-offs relevant to fast optics.
Nov 24, 2025
