Keywording In WBPP For Multiple Nights, Flats And Dark Flats Not Taking Keyword Like The Lights And Darks
2 replies132 views
Benjamin DeHaven avatar
I always seem to have this problem where the flats and dark flats don't seem to take the keyword that the lights and darks do. I usually build my folder structure to include, for example, IC1396_N1, IC1396_N2 and so forth. When I do this the lights and darks use Keyword N1 or N2 but the flats and dark flats use the date. I'm not quite sure what I'm doing wrong...
I had to manually change the one group of flats to 2023 instead of 2024 in order to keep them from lumping in with the other flats taken the same calendar day (shot both tonight and this morning after midnight in two sessions).
What might I be doing wrong? It make it so I have to manually link my lights to my flats and its kind of annoying... Thanks!
Benjamin
Adam Block avatar
One issue is that you are using IC1396 as a KEYWORD. A KEYWORD should appear only once in a path statement.
Note that you have "IC1396" in both your filename AND your folder name. This is why you see values of "2024-08-12" in your calibration panel for flats.
You need to make the Keyword unique and save yourself some frustration.
To remedy this- if you want to use the folder method- name your folders:
Elephant_N1
Elephant_N2
Elephant_N3
Put your lights AND flats in these folders. These lights and flats will be distinguished by the values of N1, N2, and N3.
I keep telling people to be creative.
Unique keywords and really… any values at all.
Elephant_Circus
Elephant_Savanna
Elephant_Barnum
Make certain you are doing this for the "Pre" and no Post when you add the keyword.
Does this answer your question?
-adam
Adam Block:
Elephant_N1
Elephant_N2
Elephant_N3
Unique keywords and really... any values at all.
Elephant_Circus
Elephant_Savanna
Elephant_Barnum
-adam
There we go! Thank you so much! 100% better! I see now...
Benjamin
Green banding issue in WBPP when using flats
Does anyone know what might be causing this green banding? I’ve never encountered this issue before, and it disappears when I exclude flats from WBPP. I have inspected my flats, and they seem normal. I’ve yet to try retaking the flats or do more test...
Discusses flat frame issues in WBPP, directly relevant to flat calibration problems.
Feb 7, 2026
Multi Night Stacking Question
I image with a DSLR and don't have a constant setup, I have to tear down every night. Often the "astro lens" comes off for day shooting. So I shoot new flats with every session. When I go to stack and have data from multiple nights, I w...
Keyword organization directly addresses multi-night flat management in stacking software.
Dec 20, 2022
Flats adding to images instead of subtracting in PixInsight WBPP
Astro Friends, I have been imaging for about 5 years and have been successful using refractors and mono imaging. I have branched out this year and now have an SCT and mono setup. I am seeking help with my flats which seem to add themselves to my imag...
Addresses flat frame behavior in PixInsight WBPP processing workflow.
Jan 2, 2026
Take one cloudy night to do all your calibration frames
I hate spending time taking calibration frames, but they are important. In one cloudy evening tonight, I have: Taken 16xdark frames at 30s, 90s, 180s and 300s each Taken 20 flat frames for Lum, Red, Green, Blue, Ha, Oiii and Sii Taken 20 dark flat fr...
Addresses flat and dark flat keyword issues relevant to calibration workflow.
Aug 24, 2022
