Objective Way To Tell If I Have Enough Signal In My Single Exposures
3 replies234 views
Benjamin DeHaven avatar
Is there an objective way to tell if I am exposing long enough for good signal in my lights? I know the rule of thumb to expose so the histogram in NINA is just off the left side. But I want something more definite than that. I use the NINA Optimal Exposure Calculator but that seems to give figures that are way too short for my liking (often in the 120s range). I'm thinking of a piece of software that will read the SNR of a .fit file or a specific part of one and give me a number that I can say for sure is ok or too low. I have a 75mm f/5.4 refractor and an ASI294MC camera and find myself usually shooting at 300s through an L-eXtreme. I was out in the smoke filled skies the other night and ended up with data that was too dim requiring a more aggressive stretch than I would have liked. If I had some kind of check I would have exposed for longer. I am often shooting emission nebula that I don't always expect to see much of in the NINA autostretch. I have even broken down and stacked a few lights in the field in Pixinsight to preview an image to see how it progressing but again this is not ideal. Thoughts?
Benjamin
Christian Großmann avatar
Hi Benjamin,
thats a tough question, which usually lead to long discussions in other threads. But I try to answer this one with my own thoughts, although I'm not sure that others may agree. But what I'm sure of is, that there are many others that don't agree
From what I have learned, I know that the SNR in a single frame increases with exposure time. So when the signal doubles, the noise increases only by the root of 2. That means, the longer you expose your sub, the better the SNR will be. But obviously, there are some limitations like light pollution, seeing or guiding performance. I am not going scientific again, because that may be a battle I loose. I'm no expert on that. But for the basics, I prefer this video: https://www.youtube.com/watch?v=1PUTWfWgD0g
However, where I live, the conditions are ok-ish. So my goal is to maximize the SNR in my subs without overexposing. Light pollution is not a big deal for me in my opinion. So The limit of the exposure time is the point, where there are some pixels starting to get overexposed. You can see this in NINAs Statistics panel. There is the MAX field, where you can see the max brightness a pixel can have. Behind this number in brackets is the number of pixels, that are already overexposed in your image. I usually keep this in the range of under a thousand pixels. This might be ok if you have 10 to 20 million pixels in total. But it depends on the target. For a bright object (i.e. globular clusters), this might be too much. For really faint things, this number might be even a bit higher. So you can decide for yourself, where the useful data should be found in the dynamic range of your sensor. That is how I usually deal with those things. For narrowband, the guiding performance of your setup might limit the max exposure time. If the stars get too blurry while exposing 1800 seconds, it might not be worth it to maximize the SNR.
I guess thats not exactly the scientific way you are looking for. But I doubt, there is a generic rule you can use without taking some other things into account. For me, it's just a mix of experience, trial and error and confidence in the experience of other photographers (looking at the image details of their images).
The Optimal Exposure Calculator brings up too short exposure times for my taste as well. I assume, the developers are referring to the known presentation of Dr. Robin Glover, which seems to split the astro photographers community in half. He seems to be much cleverer than me, but there are some things that are at least questionable. (Without any further comment on this)
So I hope this might be of some interest to you. If not, please just ignore me...
Christian
The Optimal Exposure Calculator will give you the only sensible answer to the question "how long". Anything else is meaningless as there is no way to know what is supposed to be the end SNR and to what ends. Expose as long as you can afford would be my short answer.
Keith Mombourquette avatar
I use the same process as Christian describes above.  On something like Andromeda or the Cat's Eye Nebula, I keep the number of pixels that are maxed out as low as I can while still getting the full dynamic range of my camera.  Otherwise, I look for something in the hundreds of pixels at max.
Well Written Concise
