For some time now I have been experiencing this serious type of problem to which I have not found a solution for now. Photographing at long exposure although the guide maintains acceptable values (RMS tot: 0.58 -0.70) at a certain point the stars are moved. I noticed that this happens when the DSO approaches the meridian (even an hour before and in any case when the tele points very high). I checked that there are no pushups, pulling cables and whatnot, but everything is fine! The pole alignment has also been redone and we should be precise enough. What I can still point out is that a short time ago I had redone the registration of the worm and gear wheel coupling on the two axes, bringing the driving graph to definitely lower values. Furthermore, I believe that if this registration had been incorrect, the guide would not have been so efficient. Technical data: NEQ6 pro mount, Apo triplet Astroprofessional 102/714 reduced to mm. 570. Driving with Skywatcher 70/500 and Orion Starshoot and Atik 383 L + CCD. Any advice and suggestions welcome. Clear Skies.
