'Exposure Failed' on ASi1600GT
1 reply83 views
Tim Richter avatar
Hello everyone,
last night, I took some exposures of the crescent nebula. All went fine and well, I was able to take some great OIII images. The sequence ran over night, and the equipment powerd off when done. In the morning, as I tried to take flat frames, the camera decided not to work. Every time I try to take an expusure, the timer runs, and then the software reports 'exposure failed'. The fans of the camera are running, and the filter wheel works.
My setup is:
ASi1600MM GT
ASi AIR Mini
What I've tried so far:
- Restart and reconnect equipment
- Reset ASi AIR firmware
- Connect a different camera (the 2600 works)
- Tried different 3.0 cables (no result, not a cable issue)
- Connect the camera to ASi Studio software (same result, not a Asi AIR issue)
I still want to try to connect the camera with a 2.0 cable, to check if the 3.0 port is damaged.
Are you aware of any kown issues with this camera? Kind regards,
Tim
Well written Respectful
DavesView avatar
I was getting exposure failed messages on an AA+ from an ASI6200MM Pro due to timeout. The process and transfer time was so long, around 20 to 25 seconds. Switched to NINA and the transfer time for 118 MB files was less than 2 seconds. That shouldn't be your problem with a 4/3 sensor. Suspect… camera. If you have the capability, run it through a NINA session.
ZWO 2600 MC 2025 Version Troubleshooting - Missing frames and exposure failures
Hello to everybody, I need help to solve a strange problem with my new Zwo ASI 2600 MC Pro. I bought the 2025 camera and when I first tested it I noticed this problem: sometimes it did not save the sub in the memory but the asi air kept saying that i...
ZWO camera exposure failures match your ASi1600MM GT issue exactly.
Dec 1, 2025
Damaged USB 3.0 port on 2600MC Pro camera repair suggestions needed
I had a cable management issue a couple of nights ago. Unfortunately, I think the USB 3.0 port on my 2600MC Pro is damaged. The cable was severely pulled to the side and now I’m getting exposure failures. Does anyone have any suggestions on how I cou...
USB port damage could cause exposure failures like yours.
Sep 21, 2025
