So I have discovered that I have a light leak in my imaging train using my Rokinon 135 lens. I am using a ZWO 6200 attached to the 5 position filter wheel ( tilt plate removed) the ZWO EOS adapter, and that is connected to the Rokinon 135. Through trial and error, I have narrowed it down to the adapter that is causing the light leak. Wanting some help if anyone has the same issue and/or any solution you may have for this.
