Best filters with the 2600MC Pro
ZWO ASI2600MC Pro 3 replies97 views
Michael McNerney avatar
Since my 2600MC Pro is new to me, I have been researching filters - watching a lot of Cuiv and reading all the technical data - but I'm curious which filters the average users of this camera prefers. I have the Optolong L-Ultimate and L-Quad Extreme, but have only, up to this point, used the L-Ultimate for anything other than tests. What are you favorite filters? What do you look for, or look out for in filters?
Dale Penkala avatar
Michael McNerney:
Hello Michael,
I’m no expert but I’ve used my UV/IR Cut filter, L-Pro & my NBZ filters with my 2600mc pro. I’ve been very happy with the results although if there was a change that I’d make I’d probably replace the NBZ with an Antila ALP-T. While I’m happy with the results of the NBZ I think the ALP-T would give a better contrast and band separation.
Dale
Dale Penkala:
Michael McNerney:
Hello Michael,
Dale
Thank you, Dale. Have you tested the Antlia? I considered the ALP-T, but went with Optolong L-Ultimate - mostly because I found a great deal. And to get a hot buy for 3nm is like winning the lottery.  Since my original post, I have now used the L-Quad Extreme on the Helix Nebula - a bit low in the sky, so I was curious about the light pollution levels low on the horizon. At 180 sec subs, there was a pretty definite gradient. Also, interesting that there is a "halo" around the Nebula, which seems too perfect to be part of the Nebula. Since I'm using a Ritchey-Chretien, there is no glass in the image train, so I'm guessing it's like a star halo from the filter, but around the entire nebula. I have played around to try to remove it in post, but it's very stubborn. Curious if you've ever experienced a halo from the filter around an entire nebula.
Dale Penkala avatar
Michael McNerney:
Dale Penkala:
Michael McNerney:
Hello Michael,
Dale
Hello Michael,
Funny you should ask about a comparison! Yes I did and you can see my results as well as images taken with it. Here is the comparison: https://www.astrobin.com/uz2syz/E/?nc=&nce=
The difference is very slight in the comparison but when you truly process the data it really makes a difference at the 5nm verses the 10nm.
As far as the glow around the nebula goes, no I’ve never run into that particular issue. I know that there are threads about halo’s around stars with some of the Optolong filters in particular the L-Pro (which I have 2 of them 1 for each of my rigs) and I haven’t really found it to produce that kind of halo’s I’ve seen. Maybe a slight one but its never been anything I’ve not been able to fix/adjust though processing.
Dale
Planetary camera recommendation for pairing with SLOAN/UGRIZ filters
I'm looking into procuring an astro camera (preferably from ZWO because I use an ASIAIR) that has high sensitivity outside the visual spectrum so I can perform tests with SLOAN/UGRIZ filters and maybe some spectroscopy work on the side. I will be...
Discusses camera and filter selection for specialized astronomical imaging work.
Aug 18, 2025
Etaloning effect with 2600MC and dual band filters
Hello all, I’ve been trying to work out the cause of what seems to be an issue with an etaloning effect in my images recently. I’ve only been imaging for a little over a month now but this is the first time I’ve seen this. Doing some research, I’ve r...
Directly addresses etaloning issues specific to 2600MC and dual band filters.
Jan 4, 2026
