Balancing a wedge mounted SCT
4 replies145 views
Heather Charron avatar
I recently added a wedge and auto-guiding setup to my Celestron NexStar 8SE fork-arm mount and am concerned about the weight distribution and stability of the 60mm guide scope and camera. I mounted the guide scope on the side opposite the fork arm, but now I'm worried that it should've been on the other side because it was really unstable the first night I took it out. Also, the guide scope is only attached with a tiny universal dovetail (that looked a lot bigger online).
Does anyone have some suggestions on how to better balance the mount and SCT as well as what I should use to stabilize the guide scope. I was looking into larger dovetail bases and rails, but I'm really not sure what to choose and how to go about mounting them to the SCT.
Also, I know I'm pushing the mount and am either at or over it's limit, but I'm on a tight budget and trying to do the best I can with what I've got.
Jean-David Gadina avatar
Can you change the position of the tube on this model?
If not, balancing would probably require adding counterweights on the OTA.
I know I'm pushing the mount and am either at or over it's limit.
Are you sure about that? You should probably weight your current setup and check the maximum capacity of your mount.
Never mind, I just checked the specs, and it looks like you're at the limit as soon as you put something on the scope…
I thought the mount would have a little more room for extra weight.
@Jean-David Gadina I can slide the OTA, but I actually found a forum on Cloudy Nights all about adding longer mounting bars.
https://www.cloudynights.com/topic/310985-rail-extension-options/
I think that answered my question and will give this a shot - unless anyone else has a different idea.
Rostokko avatar
The similarities of the path you are following with what I went through at the beginning of this year are impressive. I understand you do have financial constraints; I can only tell you that it took me a while going through frustration, the thought of stopping and not going deeper into the hobby and the investment in several "patches", before I did realize the nexstar mount is just not designed/the right piece of hardware for doing astrophotography beyond moon and planets (maybe).
Yes, I did spend money on a better mount, but there are good opportunity with used items and I also recovered 20/30% of the cost by selling the nexstar. I don't have to worry anymore during clear nights whether the mount will let me do what I am planning to do. I have been having plenty of fun since, and I now enjoy different kind of challenges (but intellectually stimulating ones!) as I progress through different DSO targets.
I know everyone's situation is different; I am just telling you that I believe you are trying to squeeze out something from the nexstar mount that the hardware is not able/meant to support. Take it for what it's worth it.
ADM Vixen vs ADM Losmandy for C8 ?
Hey all, hoping to get some advice. I have my Redcat 71 currently sitting on my AM5. I am looking to put my C8 on and swap between the 2. I was wondering what dovetail bar I should get. I know the C8 isn’t technically “heavy” but I’m unsure if when f...
Both posts discuss concerns about whether their telescope mounting hardware and accessories are adequately sized and positioned to maintain stability and support for their imaging setups.
May 31, 2024
12" Truss Newtonian f/4 or 14" Truss RC f/5.3 for astrophotography
Hello, everyone. Context: I am currently working on my backyard observatory which will be a completely homemade automated dome and will be ready sometimes next year, hopefully before summer. I have started documenting myself to pick a new telescope w...
Both posts discuss concerns about upgrading or modifying telescope equipment setups for improved astronomical observation capabilities.
Oct 21, 2024
Dovetails just informational
I want to share something that literally was unclear to me for over a decade. Yesterday I had to sort out the terms to help a friend buy the right parts to mount a guide scope and realize this info might help other newcomers too. There are generally ...
Both posts address the practical challenges of selecting and installing guide scope mounting hardware on telescope mounts.
Apr 11, 2025
Full rig recommendations for beginners
So I put together this list of my personal recommendations for some beginner astrophotography rigs. It was an idea for a youtube video that I uploaded and I thought I share them here and see the community's feedback! One of the most frustrating t...
Both posts address practical challenges and uncertainties that beginners face when setting up astrophotography equipment and seeking guidance from the astronomy community.
Aug 27, 2024
