I'm using NINA with the ASI2600MC remotely and would like the $$TARGETNAME$$ to be included in the FIT filename. When I place $$TARGETNAME$$ in the filename options, and took an image of M13, it shows up as "$$TARGETNAME$$" rather than "M13".
At my home setup using ASIAIR and the same exact camera, the filename does show the actual object being imaged. How can I get the filename in NINA to do the same? I open "Options-Imaging" and see where to do it but it doesn't work. Should I put $$TARGETNAME$$ in a different part of the filename path?
Thank you,
Jerry
Thank you,
Jerry
