Heads Up - Pegasus, Planewave, and the Delta-T
Timothy MartinBill McLaughlinHabib SekhaWillem Jan DrijfhoutRafa
41 replies1.5k views
Timothy Martin avatar
I just heard from Pegasus that in the next Unity update, they are going to decouple the "Agressiveness" setting–that is, there will be separate aggressiveness settings for each dew-heater power output. This was something I asked for several months ago. My hope is that this will allow me to get rid of the Delta-T and to tailor the amount of power that goes to the primary and secondary dew heaters on my CDK.
I know it has long been an issue with the Delta-T that it pays no attention to the actual possibility of imminent dew formation. And I know that others more handy than I am with such things have developed custom electronic solutions to activate the Delta-T only when dew is an immediate threat.
I also know that a single aggressiveness setting on the Pegasus causes either (1) underheating of the primary when using a setting appropriate for the secondary, or (2) overheating of the secondary when using a setting appropriate for the primary.
I'm hopeful that this new software release will help many of us solve this issue and make it possible to pursue a more intelligent and precise procedure for preventing dew in CDK units. I'll give this a shot as soon as possible and report back my findings here. I should be able to easily tell whether this is an effective solution since my scope is at Deep Sky West, which is at the height of monsoon season when humidity is often very high.
Wei-Hao Wang avatar
This is interesting.  Thanks for sharing.
I am curious what's the disadvantage of the current Delta-T?  It constantly applies heating even when there is no threat for dew on the mirrors.  Is this a bad thing?  Personally, I wouldn't want the heater to be turned on or off in the middle of the imaging.  This would lead to rather sudden changes of mirror temperature and therefore a fast drift of focus in a short time period.  I would rather prefer the mirror temperature changing smoothly (with the change of ambient temperature), even if this means heating when there is no threat of dew.
Others more knowledgeable and authoritative than me can better answer some of these questions, but my understanding is that constant unnecessary heating is far more deleterious to the quality of imaging than the slow and gentle application of heating the Pegasus supplies as the temperature starts to close in on the dew point.
Here's an extremely long thread that discusses many of the issues in excruciating detail:
https://www.astrobin.com/forum/c/equipment-forums/planewave-cdk14/fan-operation-without-efa/?page=1
It's worth noting that the Pegasus already does a splendid job of controlling the CDK fan, as also outlined in great detail in that thread. So this release should render both the Delta-T and EFA functionally useless if it works as anticipated.
Wei-Hao Wang:
Btw, I've seen the Delta-T do exactly this. Depending on the difference between ambient and primary or secondary temps, the Delta-T may turn the heaters on or off quite often, or ramp up and ramp down power often. And if you look at some of the graphs posted in the thread I linked to above, you'll see some pretty wild gyrations of mirror temperature--particularly with the secondary.
The best solution would be to have the Delta-T be sensitive to the dew point, not just ambient and mirror temps. Planewave used to supply a piece of software that would help with this, but they've since withdrawn it (see https://www.astrobin.com/forum/post/64320/).
But use or non-use of this feature is, of course, completely up to you. I'm just reporting what Pegasus is telling me, and I do indeed intend to use it.
Habib Sekha avatar
Thank you for the heads-up and your efforts. Highly appreciated!
I took delivery of my first PW (CDK14) last week, so will follow this with much interest.
John Hayes avatar
Wei-Hao Wang:
Any temperature difference between the mirrors and the air will cause convection.  It does not take very much convection to introduce ~0.5 - 1.0 waves of wavefront error into the light path.  This is something that is VERY easy to see in interferometry.  Just putting your hand into a light path can introduce many waves of optical path difference due to the heat flow from your hand.
The primary driver of temperature difference is radiative cooling to the sky.  Since the secondary mirror points down, it generally remains at or near the air temperature so this is a problem that affects mostly the primary mirror.  Under the right conditions, the temperature of primary mirror can be as much as 5-6C below the air temp and if that’s less than the temp-dew point spread, you’ll get dew (or frost if it’s cold enough).  In general, the best way to run the Delta-T is to set it up to keep the primary mirror within ~0.5C of the ambient air temperature.  The big problem is that it’s hard to heat the mirror perfectly uniformly and to measure everything to within +/- 0.25C so this setting might not be sufficient to prevent dew should it occur.
My own approach is to minimize heat to the mirrors until it is actually needed to prevent dew.  I’ve found that the best way to insure that the optics are at the same temperature as the surrounding air is with properly arranged fans.  Convection prevents micro-convection at the surface of the mirror and helps to insure that the mirror surface stays at the same temperature as the air.  The trick is in “properly” arranging the fans.  Poor air flow can make the image worse; whereas proper air flow can make improve imaging.   I’ve seen both in my telescopes but I can’t give you hard rules for getting it right beyond experimenting.  I can say that the side fans on my ASA600 blow filtered air over the surface of the primary and that approach works extremely well.  The fans work so well that the telescope does not even have mirror heaters.  The rear fans on my CDK20 did not work well at all.  So YMMV.
Just FYI, Pegasus released the feature that allows separate aggressiveness settings for each dew port on the UPBv3. It requires you do apply both a software and a firmware update.
Well Written Concise
Bill McLaughlin avatar
It would be interesting to know what settings you wind up using on the UPB dew heaters once you get this configured!
Bill McLaughlin:
I will definitely update this post then. I can't do a lot with it yet because my second Delta-T is in the shop for repair, Despite the fact that I heeded the advice of others on AB who insisted that hooking the Delta-T power into the UPB would burn out the Delta-T, I've now had it fail twice. Planewave replaced the first one. But the second one is in Michigan right now. Once it's back, I'll use it only for mirror temp readings so I can adjust the UPB settings.
When I'm comfortable with the settings, the stupid Delta-T and EFA will take their proper places in the landfill where they'll be slightly more valuable to the world as rat houses.
I have to say, after my experience with Planewave and the experiences of several friends and colleagues with them, I will never give them another dime of my hard-earned cash. I wish I had gone with someone else for this rig. It's been nothing but problem after problem since day one. Some of the problems it continues to have I will never solve==like a mysterious reflection somewhere in the OTA tube or baffle tube, imprecise collimation leading to uneven vertical diffraction spikes, other strange artifacts, and software that has a 1999 feel to it. I just don't have the knowledge or energy to keep flying out to Santa Fe to try to deal with these kinds of issues on a brand new scope. But I have it easy. One of my friends who has a CDK24 in Chile has been unable to get it up and running after a year of trying. You'd think that if you spend $100k plus stiff import taxes on a piece of hardware, the company would bend over backwards to make it work. Nope.
Yes, I'm a little salty about Planewave. It was supposed to be the best. But after 21 months of busting my butt to make its product work, I have to deal with the reality that it never will be quite right. OTOH, my experience with two remote Tak scopes has been superlative. They've been 100% perfect since the beginning. At some point, I may dump the CDK and go with AGO or ASA. They seem to be the only real options in the 2500mm fl range.
Timothy Martin:
Maybe just ASA since AGO no longer makes scopes. I had a 10 inch AGO and collimation was probably the hardest of any scope I have had and I have had an OGS, two RCOS and the AGO as well as the present Planewave. I have to say that overall the Planewave has been the best although still could be better.
The sad  thing about PW is that they have a scope that is 90% there and would be 100% if they would just listen to what the customers are saying.
Daniel Carter avatar
Bill McLaughlin:
Timothy Martin:
Unfortunately, AGO isn't making scopes any longer like you mention.
I opted for the 12.5" AGOptical iDK because Dave Tandy mentioned that the collimation for the 10" was more difficult. I haven't had any issues with collimating my 12.5". It is much easier than my Tak Epsilon 160ED!
PlaneWave scopes do work well once you work out the gremlins. We host 4 different PlaneWave scopes and the experience with all four has been completely different. Our CDK14 has been flawless. The only work we have done was to collimate the scope with SkyWave. Our CDK20 was purchased from another user who did all of the work to get that system performing well, which John has plenty of documentation about his journey on. The fans still cannot be on during imaging at all, or we end up with triangle shaped stars. This is something we are exploring a custom solution for as we would at least like a little airflow to break up the boundary layer on the mirror. The scope does take excellent images though so this hasn’t been a high priority for us.
The DR500 takes a lot of work to collimate, adjust tilt, and we still see some optical flaring on very bright stars. We’ve explored a number of fixes for this and haven’t found the silver bullet quite yet. We aren’t alone with this issue though as other owners of DR’s in general report similar results in very good setting conditions on brighter stars.
The CDK700 is just flawless. Setup and collimated it, did some work to solve a minor modeling problem, but that was it. We’ve seen some interesting issues with derotation here and there that we’ve started looking into but we expect this system will just produce data like a champ.
If they could get the experience across their products to be consistently more like what we saw with the 14 and 700, that would be more ideal. I’ve also heard very good things about customers experiences with the CDK17.
Habib Sekha avatar
My Delta-T stopped working after two nights. The power LED is on but besides that it does nothing. Happend in the middle of a sequence on a very rare clear sky here at the border of Netherlands and Germany.
The Delta-T is powered by the adapter which came along with it.
Let’s see what the distributor says about it…
Habib Sekha:
Stopped working or stopped communicating with the software and (therefore) cannot be set to an operating mode? I have found the USB connection is not reliable.
Habib Sekha:
Sorry to hear that. I know exactly how you feel--it's happened to me twice. Without even really trying--that is, without researching it at all--I've now read about more than a dozen failures of Delta-Ts. Some have blamed it on using a nonstandard power supply. That's just poppycock. 12V is 12V. It's clear to me that this is a poorly designed product that is manufactured with little quality control using cheap components--but at a premium price.
These kinds of things kill companies. I would not be the least bit surprised to hear that Planewave is going under or being bought before too long. Privately held companies like that often hit the turf when the owners lose their mojo. Planewave has had a long run, but the guys at the top could well be out of gas. This is all purely speculation on my part, but I've been around startup ventures my entire career. It's a well-worn pattern. Buyer beware.
Timothy Martin:
Agreed. That would also explain why some die right away and others soldier on for a very long time. Poor quality parts often have highly variable quality as well with some being crap and others not too bad. It is a total crapshoot as to which one you will get.
In any case, that is why us owners need aftermarket alternatives for as many of the systems as possible. Some are easy (like the focuser/rotator), others not so much. No telling how long PW will survive (just ask RCOS owners about that situation )
Just another example (albeit not a critical one) is the RA "toe" counterweight shaft that came with my L-350. Supposed to be stainless but actually rusted in less than 6 months. PW said to "send it back" and they would look at it (I had sent them the photo below) A good company would just send a new one and let you send the old one back once you got it.  Very clearly just very low grade cheap stainless. Photo is after I cleaned it with steel wool, it was much worse before and  clearly not what it should have been. Worse yet, it showed early signs of this when I got the mount - meaning it was shipped that way!  I may still send it back since I am not using it at this time.
It may seem like this is a "Bash Planewave" thread but I have also pointed out that overall the scope has been good and has given me some of the best images I have ever taken. Not all of that is the scope, of course, a lot is the site.
The problem is that the system would be basically perfect with better attention to the issues that a large percent of customers have had and that PW is very well aware of. It is not like the Delta T issue is uncommon.  Add that to the nonsensical way that  PW has designed the thermal control and anyone can see the problem.
Willem Jan Drijfhout avatar
Timothy Martin:
Thanks for the heads up Timothy. Do you know if this also works for the UPBv2?
Would be great to get rid of the Delta-T. A few weeks ago I lost communication with the Delta-T, for no apparent reason. After my initial Delta-T came dead in the box and had to be repaired/replaced as well as the many stories here on AB, I was afraid this would be the end of my second copy. Interestingly enough, life was brought back into it when it was plugged into a USB2 port of the UPBv2, rather than one of the USB3 ports it had been in so far. This should not matter, all USB3 ports on the UPBv2 are fully backward compatible. But hey, it worked, so no further questions asked.... The USB connection of the Delta-T seems very unreliable indeed. So for anyone having issues, you might want to try USB2 and see if it works.
Not sure how long this solution will survive, so would be happy to try any other solution.
Willem Jan Drijfhout:
Timothy Martin:
Unfortunately, this only seems to work on the UPBv3.
Timothy Martin:
Ah, that's a bummer. Well, if it works, it is well worth the upgrade I presume.
Timothy Martin:
We'll see. So far, it has worked pretty well at preventing dew, but I'm probably overheating right now and degrading the sub quality. We've only had a couple of nights where humidity has climbed since I sent the Delta-T off for repair. When it comes back, I'll be able to tune the aggressiveness setting for each mirror more precisely. Once that's done, I can report back my findings--with the caveat that it only applies to the CDK12 (and given Planewave's quality and component variability, it may only apply to my CDK12)
Just as an aside, I have had good luck with the V3 so far and I installed it at my remote site in June. Mainly went to it to replace two others (a V1 and a PPB)   with just one, giving better NINA control…..
Habib Sekha avatar
Bill McLaughlin:
Habib Sekha:
The power LED goes on, the computer can't detect it so no way to communicate with it. If it is an USB connectivity issue then it is from inside the Delta T box. I tried exchanging the USB cable, tried various USB connections on the UPBv3 and and the mini PC, and after reading Willem Jans's post I also made sure I tried some USB2 connections. Also tried another 12V adapter just in case the original one stopped supplying enough current.
I agreed with the distributor over here in Europe that they would send a new one (free of charges) out today.  They never heard of a Delta T malfunction before... yeah sure...!
Bill McLaughlin:
So far I like the optics of the CDK-14 I received.
That rod in the picture does not look like stainless steel.
Habib Sekha avatar
Timothy Martin:
Habib Sekha:
Thank you Timothy! I had read about the headaches/pain the Delta T gave you including the loss of time and the costs you had to make.
Let's hope the problem will now be resolved.
I will keep the option of using the UPBv3 in case of emergencies in mind. I have the v3 with updated software, the cables are there, could use it at least at low power if needed.
If I recall it correctly, John Hayes used his own design combined with a humidity sensor to interrupt the power from the Delta T to the scope. If we would be able to 'catch' the temperature of the mirrors,  the Delta T might no longer be needed? That is using say the UPBv3 together with an electronic on off switch reacting to the dew-point temperature and the temperatures of the mirror?
Respectful Supportive
Habib Sekha avatar
The USB connection of the Delta-T seems very unreliable indeed. So for anyone having issues, you might want to try USB2 and see if it works.=14px
Thank you for this suggestion Willem Jan! Always good to try this option in case of malfunction. I'm glad that with this 'workaround' you are able to use it.
I tried this, this morning...no luck. I should get a replacement within a few days.
Habib Sekha:
Agreed, but it was supposed to be.
Optimized Newtonian - Is it worth it?
There are a lot of ways I can think of that the current crop of Newtonian Astrographs can be improved. Lets restrict the conversation to apertures between 6 and 10 inches. 1.) Lowering the focal plane relative to the side of the tube (eliminate the f...
Both posts discuss desired improvements to astronomical equipment through modifications to existing designs or settings.
Jul 28, 2025
Secondary mirror coating issue or possible light leak problem?
I was considering sending my secondary for my ago idk 14.5" over to terry at ostahowski optics for a recoat because if I look closely enough, I have what looks like an oil spot or something that slightly dulled a small part of my secondary coating th...
Both posts discuss customizing or improving the performance of telescope equipment through modifications or professional services.
Nov 3, 2025
Power issues!
Hi all, I'm having some issues with powering my astro gear. Whenever current draw is high (like when cooling camera), my input voltage gradually drops until it is near 10.5V. Obviously, this is not ideal for the equipment, but simply purchasing a...
Both posts discuss managing power distribution and control settings for different astronomical equipment components.
Apr 8, 2025
