Pinched optics, backspacing error....or both?
5 replies146 views
Piers Palmer avatar
I managed about two hours of imaging last night with my R200SS and have very quickly processed the images this morning; 40 x 180" frames.
I've been using the scope for years now, so have the backspacing sussed (I think) and collimation is ok (I think) but this image is weird. The top left looks ok to me, but the other three corners are horrid. Have I got a pinched mirror?
I did deconstruct the cell recently after a slight accident with primary, but I wonder if something's a bit too tight after putting it all back together.  The odd thing is, I took this image the other night with exactly the same set-up and didn't have this problem.
Can anyone help?
Piers Palmer avatar
Blurxtermintor seems to sort it out, but I'd prefer it didn't have to!
I guess it's tilt more than anything. And you used  BXT on the other one so it's hard to compare, isn't it?
Piers Palmer avatar
I didn't think I had initially, but yes, I had., so good point.
So where do I begin with tilt? Could it be caused by the secondary? The camera and spacers combo is the same as I use on my refractors which report almost zero tilt, so it's something unique to the Newt.
Could be tilt in the primary so my first port of call would be to check collimation to death. All the times I get something like that it is because, reasons unkown, the collimation screwed up one night to the next.
Piers Palmer avatar
I think my first port of call might be my 115mm apo!
Rotation shift after meridian flip (no electronic rotator)
Hello, I recently noticed that during my last two sessions of shooting that I experienced a shift in the field rotation after the meridian flip. All images taken before the meridian flip are same orientation and matches with framing assistant, and al...
Field rotation issues could cause uneven corner quality across frames.
Oct 28, 2025
Shifting primary mirror
Hi All I hope that you have some experience that can help me here. When I image low on the horizon, my stars are not good📷 image.png Near Zenith - same star. 📷 image.png Yesterday I realised that my Primary mirror shifted - and that most likely was t...
Primary mirror problems directly match author's suspected pinched mirror issue.
Mar 6, 2026
Odd "circle" in imagery when taking photos
Hi all, Starting with: This is a 12” newtonian (1200mm), with a Poseidon-M connected to 50mm (round) filters and an OAG-MAX (with a coma corrector) - 56mm back focus So I’ve been banging my head against a wall trying to figure out what this is… I fir...
Optical artifacts in imagery may help diagnose corner degradation causes.
24 days ago
Another weird cdk star halo issue!
I just recently got my brand-new scope back from planewave after a couple months, they had to refigure both mirrors entirely unfortunately!! While everything seems to be working tons better than it was before I’m still getting some weird star halos. ...
Mirror issues after deconstruction similar to author's recent primary accident.
Sep 5, 2025
