Unguided Dithering
8 replies317 views
Jerry Gerber avatar
Hello,
I'm doing an unguided image tonight with a 10MicronGM1000 mount.  In NINA, there's an option to dither, which I turned on.  But I am not sure that the images are being dithered unless autoguiding is used.  Am I right or wrong about this?  It appears the images are not being dithered but I could be wrong.  I also don't see an option in NINA to choose by how many pixels I want to dither by.  Am I missing something?
Thanks,
Jerry
Stjepan Prugovečki avatar
I am doing this all the time (have a mount with encoder, so, no guiding) . Under "Equipment" you have to chose Guider , select direct guider and connect to it . There you can set dithering parameters. Then in imaging sequence you enable dither and set how frequently you wish to do it. If you done all this and yet you have a feeling that images are not shifted, then adjust for how many pixels you want to shift  on dither command. For me it works like a Swiss watch.
Jerry Gerber avatar
Stjepan Prugovečki:
Hi Stefek,
Thanks for replying!  I don't understand, if I am not using my guide camera, and I turn off guiding, the mount is using the encoders to track.  The stars are looking excellent and round.  I've disconnected the guider and PHD for now so I guess my question is, if the mount is relying only on the encoders for tracking, which it is,  and I turned on Dither in my sequence, is the mount dithering?  I think it is, as I notice very slight image shift, but not 100% certain.
Jerry Gerber:
Stjepan Prugovečki:
Hi Stefek,
I am not using PHD in such cases. I am using for this case direct guider that is par of NINA. When you connecting to that direct guider, you can setup how big (in pixels) your dither will be. For a trial , you can set it to 20 or 30 pixels and then it will be visually more than obvious. I hve that value set to 14 pixels (100/800 scope with IMX571 based camera.
Concise
Jerry Gerber avatar
Stjepan Prugovečki:
Jerry Gerber:
Stjepan Prugovečki:
Hi Stefek,
Got it!  Thanks Stefek..
Mark James Ford avatar
Hi Jerry,
This may seem really silly (sorry if it is) as a comment but it does assume that the GM1000 is mounted in NINA (which would mean that you would have all the very many advantages of the (excellent) 10 Micron NINA plug-in ;-).  (I used NINA for a good while without having any connection to my GM1000 mount). Once connected the direct guider dithering works just fine.  The randomness of the dither is only in the direction of the dither, the dither amount is always the same.  The direct guider is not actually doing any guiding per say, though the virtual key pad will show the symbol that it is being controlled at a "custom rate".
Cheers, Mark
Jerry Gerber avatar
Mark James Ford:
Hi Jerry,
Cheers, Mark
Hi Mark,
Yes, I figured that out. I am imaging with NINA and once I connected the Direct Guider dithering works fine.
As i said, apologies for the obviousness …
Jerry Gerber avatar
Mark James Ford:
As i said, apologies for the obviousness ...
Don't worry.  You were being helpful.
