What is real and what is not? How to know what to include...
12 replies776 views
Christian Großmann avatar
as I always stated, image processing isn't my thing. But while forcing myself to progress in this field, I ran into some issues no tutorial seems to care about. Let's explain the problem.
For my latest images I took the time to collect at least 15 hours of data. This is a general rule I created for myself. So I collected a lot of data on less images and I am always excited to see what the master frames look like. Who won't? When I open the masters in Pixinsight, they show a lot of things going on especially in the background. As many tutorials about DBE or similar tools show, there are always gradients of different kinds visible. That's what these tools are designed for and they handle removing them really well. But I wonder, if all the stuff that I try to remove is really trash. There are two main examples:
1)
I did image Markarjans chain the other day and the masters showed a quite foggy background. You might see it in the image I uploaded. The structure seems to be weird for a simple gradient. So I wonder, if this may be real. The color is quite neutral and so it must be on every color channel and the Luminance as well. (I can't look at the masters at the moment) It looks like it belongs there. But how do I know? Are these things real and should be left in the image? If they are real, they should appear with longer exposure times, shouldn't they? We do take a lot of subs to get those details out of the noise, right?
2)
The same exact thing happened when I imaged M81 as well. You can't see it as detailed as on the Markarjans chain image, but it is there. And it is even better visible in the master frames. The background of the uploaded image was darkened a bit too much, but it hides those things. I wonder, if it has to hide those things.
So there are some questions I need some answers or suggestions to:
Are those things real and if not, what causes such strange things? Is there a way to avoid them? There are other subjects I imaged where the background is quite even and has no issues at all.
If the details are real, why then so many people seems to work so hard to remove them? I understand the "beauty" of clean images as art. But from a scientific point of view it might be a bad idea to remove this stuff.
How do YOU decide whether such things are part of the sky angle you image? At least I saw some images of M81 on the web, that showed such foggy regions around the galaxy (distances not taken into account). So I am not the only one who experienced these things.
So what is real (and in my opinion should be included in the final image) and what is not real (and should be thrown out)?
Thank you for sharing your thoughts.
Christian
Marc-Antonio Fischer avatar
This is not real. The cause can be several things, like walking noise pattern, poor flat calibration, light leaks in tube or around focuser, sharpening and then do noisereduction artefacts.
Todd Anderson avatar
There's a few different parts to your question, so hopefully I don't jump around too much.
First off, figuring out what's real and what's not: Personally, if I see stuff in my image that I'm not sure is real, I go right here to Astrobin and looks for images of whatever object I'm working on, and find multiple that seem to have gone really deep on bringing out faint stuff (could scroll through everything, though I usually filter to IOTDs and Top Picks). I'll take a look at the area I'm confused about and see if I can find that same shape/structure in other deep images, and if I find it, I look at another, and another, and another. If I'm finding the same structure in multiple images, I know what is in my image is real. If I've been through 15 other really deep images, and see a lot of faint stuff, but not the "object" I'm confused about, I assume it's not real.
Second: "if the details are real, why then do many people work so hard to remove them?" Any number of reasons. They didn't know it was real. They didn't have enough integration time or dark enough skies to get the faint detail (so in this case, they didn't remove it, they just never got it in the first place). Or in some cases, it's there and they know it's real, but there's just not enough detail to actually bring it out in a clean way, so they smash it into the background in favor of a cleaner picture. That was the case with an M31 I did. I got enough Ha data that the really faint surrounding Ha was actually in the data - if you overblew the saturation, it showed up and was in the right location and right shape, it was definitely there. But it was just so faint that any attempt to bring it out just made it look like a poorly managed background, so I had to just give it up and go for the cleaner background instead. Had I gotten enough integration time that I could bring it out, I absolutely would have, I just didn't have the integration time needed for stuff that faint.
As for your images: On Markarian's Chain, I couldn't tell you for sure - I don't know that area very well. I'm not aware of any IFN or other faint background stuff sitting around in that area, so my guess would be noise, but someone else may know better than me. Don't take my word on that one. For M81, there is absolutely IFN around it, and quite a bit of it. You'll find plenty of images that have it if you want to compare yours to see if the dusty spots line up (I don't see any in your attached image, but you mention that it shows up better in the masters, so it may still be there somewhere). People love the IFN around M81/M82 so if you search it up here on Astrobin and you'll find tons of images with it (my image of it on my profile has it if you want an easy one to find).
Essentially, a very long-winded (as I tend to be) way of saying that it just comes down to researching your target. Asking community members if stuff is real is also viable, but I tend to just go find it on my own so I don't have to wait on the answer.
Take a look at this extremly long exposuretime: https://www.astrobin.com/f2u321/B/
There is a very very slightly IFN around M86, but not as much as on your image. This guy really trys to press out every detail on this image and as you can see its not that easy to caputre it and looks totaly different then on your image. sorry :/
Oskari Nikkinen avatar
Not sure how much IFN there is around the Virgo cluster, but M81 is very busy with it. It is rather faint though, so easily mistaken as a spotty background or odd gradient due to some data issue or light leak. In my previous attempts at the target i saw a weak something in the background at around 4 hours from Bortle 4, and it only became obvious as IFN at more than 10. In order to make an appreciable attempt at processing it out i ended up going for more than 30 hours.
That 30+h attempt can be seen here : https://www.astrobin.com/llbasd/B/
Helpful Insightful
Jon Rista avatar
Marc-Antonio Fischer:
There is more to it than just the amount of exposure. He also has very dark skies. The original poster's images exhibit signs of light pollution, and that is the SINGLE LARGEST factor here that us limiting his ability to get deep IFN details, as well as more easily identify IFN from pollutant signals.
Christian Großmann:
1)
2)
Christian
As I mentioned above, both of your images here demonstrate signs of light pollution. Not necessarily particularly strong LP, and you are picking up a little bit of IFN, but you have enough LP to be problematic. With 15 hours of exposure, you have been able to reveal some moderately faint objects, but you are having trouble with the IFN due to the LP.
LP does not just add noise...it is a pollutant signal. The image that Marc-Antonio linked to was acquired under much darker skies. Even with those darker skies, capturing very faint details still requires a lot of time...but not nearly as much as if the imager was ALSO fighting LP. You mentioned 15 hours...assuming your skies are say around 10-15x brighter than a blue zone dark sky, you would need AT LEAST 150-225 hours of data to pick up some IFN or other faint background structures. AT LEAST.
The key problem with LP, though, is it is not just additional noise...it is a pollutant signal, and that signal isn;t always uniform across the field, and it is not necessarily JUST a simple gradient. My experiences imaging under very light polluted skies, and constant fiddling with the data, acquiring as much as possible (I've acquired as much as 40 hours of data on a single object under my Bortle 8/9 skies, which are around 20x or so brighter than a blue zone, and the benefits of all that time were minimal at best, and I had EXACTLY the same problems as you, every time.) Extracting a simple gradient is easy. Dealing with the smaller scale issues left behind by the pollutant signal AFTER extracting the gradient...that is much harder to deal with. This often includes color noise, not just at the pixel scale, but at larger scales as well. These small to mediumish scale colord structures make it very difficult to differentiate real object signal (i.e. IFN) from pollutant signal. Usually, its quite impossible to truly separate them, and if you try to extract teh pollutant signal, you usually lose good object signal as well.
I don't think your skies are quite a bright as mine, but they seem bright enough to be problematic and limit how well you can separate real from pollutant signals. You can try to reference other images of the same region, and see if you can more carefully model and extract the pollutant signal. This can work for medium to largish pollutant signals, but for smaller scale stuff, and when its intermixed with faint signals like IFN, dark nebula, outer galactic halos, etc. you are pretty much always going to extract some amount of the real object signals as well as the pollutant signals.
IMHO, the best way to deal with this...is to get rid of the light pollution. That means...find a nearish dark site, and use that when your intent is explicitly to capture faint details. You can find such a site with this map:
https://www.lightpollutionmap.info/#zoom=4.00&lat=42.6470&lon=-85.9991&state=eyJiYXNlbWFwIjoiTGF5ZXJCaW5nUm9hZCIsIm92ZXJsYXkiOiJ2aWlyc18yMDIzIiwib3ZlcmxheWNvbG9yIjpmYWxzZSwib3ZlcmxheW9wYWNpdHkiOjYwLCJmZWF0dXJlc29wYWNpdHkiOjg1fQ==
Use the VIIRS data, within the last couple of years (although I find sometimes older years are actually a better match, not entirely certain why but around here, sometimes with the oil fracking and stuff and their burnoff flares, its created pockets of LP that can have fairly broad reaching effects (among other things that can affect localized LP levels.) Anything cyan or darker is excellent, especially if you are surrounded by it for a ways. Green is good, if its patchy surrounded by darker. Patchy green LP bubbles are usually just ranches or other small facilities outside of city limits, and they don't have much if any effect on astrophotography. Green is good, if you are surrounded by it for a good ways in all directions (several miles.) Once you get into yellow, then you are in the LP, and imaging becomes problematic again. Usually, most people can find a green area on the VIIRS map (not ATLAS, VIIRS) not all that far away. My main dark site is 35 minutes away, and its black or cyan all around. Note that VIIRS is a different kind of measure on LP than Bortle. Atlas is basically the Bortle scale in a map, and its better if you want to do visual, but it pushes you a LOT farther away from city areas to find "dark" skies according to the Bortle scale (which is specifically for visual observation),  whereas VIIRS can help you find dark sites much closer (less time, less driving, less gas, etc.)
Key thing to keep in mind is that Bortle is designed for human vision, which is about DYNAMIC sensitivity. Cameras, on the other hand, have static sensitivity, so an area that may not be all that good for visual observation, is quite possibly excellent for astrophotography. Even if you are not so far from your primary LP bubbles that they still make big bubbles on the horizon, since a camera has static sensitivity, as long as you don't point INTO that LP bubble, your camera will be unaffectd by it. So most people...can in fact find good quality dark sites much closer to home, than would generally be indicated by the Bortle scale. If you really want to go deeper on FAINT signals, like IFN...I strongly encourage you to look into your area, see if you can find a decent dark site within an hour or thereabouts, and try using it. Such a dark site will be VASTLY superior for capturing faint signals like IFN, compared to any light polluted area.
The key thing about dark skies vs. polluted skies is the contrast. You might need hundreds of hours to get enough signal, to produce a high contrast image of IFN from say an Orange or Red bortle zone. You might need 15-20 hours at a good dark site to get enough quality signal on IFN to start bringing it out. You may ultimately need tens of hours to get good, strong IFN signal (or for other faint signals, dark nebula, faint reflections, etc.), but a dark site is vastly better suited to acquiring this kind of data, than any light polluted area. Even though there is a time cost in packing your gear up, driving to the site, setting up, and then tearing down and driving home......in the grand schem eof things, that time and effort cost is FAR lower than trying to get good quality images of faint signals from a light polluted zone. Once you experience the quality of the data from a good dark site, without those frustrating pollutant signals mucking up the works, you will understand why some people seem to have an easier time of it, producing excellent quality images, than other people do. Some people just have dark skies, meaning they have, effectively, left the pollution behind.
Helpful Insightful
Byron Miller avatar
Oskari Nikkinen:
There is a TON of IFN here, where most people get lost in processing this area is that their gradient removal process nukes the IFN and causes that orange peel effect.
What i suggest when seeing this orange peel effect is to break out the luminance, try and stretch and optimize and denoise that and then pixel math it back into the RGB master so the orange peel is lost to signal and then mess with curves to try and highlight it with masks as necessary.
or get more data ;)
I haven't imaged this recently but my first attempt a few years ago i had so much IFN some people called BS, but it's there - and lots of it.
At first, I'd like to thank you all for taking the time for your very detailed answers.
@Jon Rista
I try a summarized answer to your whole text ;-) I totally get what you are trying to say. Especially in the image of Markarjans chain, there are really small structures in the background, which I never would have thought of as light pollution. But obviously, it is what it is. So that's one other thing to keep in mind in the future. Your explanations of LP is very logical and I will see, what I can do about it. Maybe I start with ensuring, that there are no light leaks in the light path of the equipment. I use ZWO filter wheels and I did cover some unused screw holes with tape. But maybe that's not enough. But this is a problem I can handle.
Sadly, what I can't deal with is my imaging location. I am situated in a really small town and I am forced to use my backyard. It might be possible to go to darker skies. Lightpollutionmap shows even Bortle 2 on some places. My hometown lies in a bortle 3 area and I know, my backyard is of course even worse. But I am lucky enough to have darker skies than so many other people here. So I am glad I live here and make the best out of my situation. But the main reason for staying in my backyard is time. I am very busy with some other communities as well and sometimes I am at the edge of what I can stand. But I am responsible for the others and trying to reduce my work with them usually means the end of these groups. So astro photograpjy is a great solution, because I was able to automate all my stuff and keep 3 scopes set up in my backyard permanently. This way, I can image during the night and still get some sleep. Going out in the fields is my preferred solution, but it means to spend a lot more time which I simply don't have.
Your answers here are not what I have hoped for. But it sadly is what I expected. So the first step is to see, if fixing possible light leaks might improve my data a little bit. I was thinking about blackening my SCT tube with a darker color as well. I'm still not sure if I will. All of the other stuff I have to ive with.
But the result of this conversation is to realize what my limits are. I had to know what is possible and what's not. Accepting these limits might make life much easier and I will not try to catch the impossible.
Rafał Szwejkowski avatar
You need to take care of dithering to eliminate walking noise and ensure proper flat calibration before you should worry about LP.  These are absolutely fundamental, otherwise it makes no difference if you do 5, 15 or 50 hours of exposure - it will all be for naught.
Rafał Szwejkowski:
But are these effects walking noise? I do dither and I use an adjustable flat panel for my flats. I try to keep the exposure times of the flats long enough to even out any possible flickering that may come from the pwm signal that controls it. I assume, my workflow is not differnt from those of others, is it?
Byron Miller avatar
Christian Großmann:
Rafał Szwejkowski:
No, doesn't look like walking noise or mis calibration, it looks to me like gradient removal took away some signal and like i said earlier, most people just go and nuke the rest of it and ignore the IFN.  Denoise will cause it to get splotchy like this in a lot of cases. What was your basic workflow for editing?
Jon Rista avatar
Rafał Szwejkowski:
I wouldn't say that. You could crush walking noise a bit into the background with a careful enough stretch, and if you imaged from dark enough skies then the benefits of that would still be realized. Its hard to describe the differences between light polluted imaging and dark sky imaging to those who haven't imaged under dark skies before. Its not about noise, as much as it is about contrast and depth. Walking noise would be at a much deeper depth under nice dark skies, and even though it might still exist, the SNR of say IFN compared to that walking noise could be much, much higher than at a light polluted site. So, even if you don't eliminate walking noise, I wouldn't say that imaging at a dark site is "all for naught"...there would still be benefits. Less than optimal, sure, but still benefits.
Jon Rista avatar
Christian Großmann:
@Jon Rista
I wanted to touch on "Bortle" vs. the Light Pollution map I was recommending. Bortle scale is NOT about imaging. IT is very explicitly about what is necessary to VISUALLY observe certain objects of certain brightness levels or magnitudes. The Bortle scale is too heavily used by astrophotographers for finding a "sufficiently dark site" and sadly, it leads many, far too many, astrophotographers to thinking that they would have to drive 100+ miles to find sufficiently dark skies for imaging. Which is actually false a lot more often than its true!
If you use the VIIRS map I recommended, that is NOT based on the Bortle scale. it is a different scale, based on actual illuminance measured at those locations from space. The VIIRS map will generally help you find a sufficiently dark site much closer to home a lot of the time. Based on what you've said about your location, I suspect (based on the LP I can see in your images) that you might be borderline as far as sky brightness goes...and you may well not have to go very far to find good skies. If you live in a small town, the LP IN town can jump by a magnitude or so, but if the town is relatively isolated, it may well be all you would have to do is get out of town by a few minutes.
Anyway, just wanted to clear that up. The Bortle scale is actually a poor way to judge sufficient sky darkness for IMAGING purposes, and it is really not necessary to find a truly dark Bortle site to have nearly perfect skies for imaging. There are times where the VIIRS map will show ideal skies (no color in the VIIRS map) when Bortle might show yellow or even brighter. Now, if Bortle is say orange, and VIIRS shows no color, then directly overhead is good. Depending on where the light pollution bubbles are, it might limit what directions you could image in without picking up LP. If Bortle is dark yellow or green, and VIIRS is no color, then its probably a pretty darn good imaging site. If Bortle is blue, gray, black, and VIIRS is no color, its a superb imaging site (which should be a given, since to find Bortle blue, you usually have to drive pretty far from any artificial light pollution centers.)
So with the VIIRS map, most imagers can usually find a viable dark IMAGING site, a LOT closer than a viable dark Bortle (VISUAL) site.
As for the answer you wanted...sadly, this is why I way LP is the worst thing astrophotographers deal with. It is some truly nasty stuff. Its not just a gradient, its a signal, and it gets blended with other signals, and because all signals have noise, and in fact LP can sometimes have structure (depends on exactly what's in your skies and where, and where that stuff falls in your field), so totally, ideally, and cleanly removing ALL LP is largely a pipe dream. You can remove the larger stale stuff. The stuff that blends into fainter signals like IFN, well, its going to be very difficult to impossible to eliminate those pollutants, and that's what makes it hard to figure out if the structure you are seeing is real or not. Even if you have a reference signal, its tough to know how clean the skies were when that image was acquired, and even if you think you know what the real structure is, there still aren't really any good ways to separate intertwined pollutant and object signals from each other. Noise will hamper that, and noise will usually occur at multiple scales hampering it at multiple levels.
If you have to image with LP, then yes, its good to know what your limits are, and how far you can push your signals around. LP adds more noise (and it will usually be noise at multiple scales, such as the colored orange peel junk). If you are dedicated enough, then you can put many tens of hours into each object, and that will help you get beyond the limitations imposed by LP to a degree. If you can get 30, 40 hours or more per object, then you can still make some nice images...but, they will lack the depth of a dark site image 1/10th, 1/15th, maybe even 1/20th the integration time. You will have a hard time getting that truly expansive contrast, which IMO is really what sets a dark site image apart from others. Dark sites won't necessarily mean you can pick up very faint signals in "little" time, sometimes you may still need dozens of hours per image, but in contrast, you would need 10-20x as many hours from a light polluted site, and even with that, you can never truly eliminate pollutant signal from everything in your images, and that will show in the end.
This is Bright Red Zone Bortle (18.2mag/sq") vs. Dark Green Zone Bortle (21.3mag/sq"), a difference of 3.1 stellar magnitudes. A difference of over 17x the sky brightness. These are identical exposures. Adjusting the stretch from both to be identical:
You can se the difference in noise pretty easily. I also worked to try and extract the pollutant signals...and you can also see how well that worked. I could work at that, removing pollutant signals, till the end of time, and it would probably still never be as good as the dark site image. Especially the center bottom area, you can see where the LP intermixes with notable structures around one of the Pleiades. Pretty much everything I did to try and extract that pollutant resulted in the extraction of the nebular signal as well. You can also se areas where I DID remove some of the fainter nebula, between some of the groups of stars, in the polluted image. I could get 17x as much signal from the light polluted site...and that might help me with the extractions. But I've done that, it takes imaging across many, many nights...and the nature of the LP shifts across all those nights, which complicates the nature of the gradients and any remnant pollutant signals, and I've found that sometimes too much polluted signal can still be just as problematic. (In fact, one of my earliest "tens of hours" images WAS the pleiades, from my 18mag/sq" backyard skies, and even after 20 something hours (and eventually around 40 when I tried to get more data), I did get some fainter details and some better contrast...but, you could still tell the image was quite light polluted, and the problem of extracting the pollutants shifted from the (actually relatively bright) inter-Pleiades reflection nebula here, to the fainter outer dust and background structures (there is actually some faint Ha in this region, not to mention a plethora of very dark dusty nebula), and I was never able to properly separate those signals from the pollutant signals in the long run, even with tens of hours. I had a decent image in the end, but, it was NOTHING compared to 2-3 hours of pleiades from my dark site.
Such are the consequences of imaging under light polluted skies. Its not that you can't image with polluted skies. As you said, know the limitations. I think once you know that, then you can focus on making the workable parts of the image look really nice, and then...maybe just let the chips fall as they may on the parts of the image that are not as workable.
Helpful Insightful Engaging
M51 .. looking for feedback
I'm looking for feedback on the image below. I know my stars are a weird shape and am trying to work out what is causing them, so ignoring those, what do you make of the rest of the image? Original: M51
Image processing techniques relevant to improving deep-sky object image quality.
Jul 26, 2022
Best way to identify galaxies
Just wondered what the best way is to identify background galaxies in your images. e.g. the one pointed to by the arrow below M51 with only 3 hours of integration
Addresses distinguishing real astronomical objects from artifacts in processed images.
Jul 13, 2022
[RCC] How bright should a Dark Nebula be?
Hello Together! I'm struggling with the "right" brightness of my latest Project! I have created several brightness Versions of my Iris with Dark Nebulas: Darkest: https://www.astrobin.com/b13gdg/0/ A bit brighter: https://www.astrobin.c...
Author struggling with image processing decisions; relates to brightness/appearance choices in post-processing.
Oct 28, 2022
RCC: Elefant Trunk Complex
I'm a bit sad and wondering about the few views of my latest mosaic Project: https://www.astrobin.com/dyqlaw/ With starting of this thread I got only 72 Views but at least 52 likes and 2 Bookmarks So I'm asking myself for the reasons … ...
Discusses image processing issues, directly relevant to author's question about editing quality.
Dec 5, 2022
