Menelaos avatar
Hey guys! So i’ve been trying to use HocusFocus in NINA to fix some tilt. It starts to do an autofocus session and it works fine but when its finished it gives me a message that says it has made an exception and then crashes. Also when i try to load a saved autofocus log it tells me that a folder named attemptXX must be selected but i cannot find such folder on my computer. I located the folder with the autofocus logs but they are not named like that. Any ideas what is happening here? I tried uninstalling everything and then reinstalling but it didn’t work.
Byron Miller avatar
did you get regular focusing to work first?  have your steps and backlash compensation set up correctly?
Menelaos avatar
Byron Miller:
Yes everything is setup correctly and it does autofocus perfectly. I actually found the problem. When you install Hocus focus you need to set a file location to save the logs. I didn’t do it before so it couldn’t find any logs to analyse. Now it works like a charm. Thank you.
Setting up NINA with ZWO EAF—Help!
I have been using my ZWO EAF with the ASIAIR successfully for nearly two years without incident. But now I’m trying to migrate to NINA and I’m having a world of trouble. I’m not sure if it’s the EAF that’s the source of the problem, but here’s what h...
HocusFocus autofocus issues in NINA may relate to similar focusing problems.
Jan 21, 2023
WBPP experiencing "Unknown exception" errors during "Measurements"
I have been having issues with Pixinsight WBPP failing to measure a significant number of sub-exposures during the Measurements step with the reason as “Unknown exception. I have posted this issue to the PI forum and this time been told to use FBPP b...
Unknown exception errors during measurements similar to HocusFocus crash issue.
Sep 28, 2025
