Hi All,
Sorry if this has been posted before. My searching skills were not good enough to find a post about this. Recently for the last couple of projects I've been working on in UV/IR cut, I've been seeing these odd embossed circles only really late into the integration. The bottom left 7 o clock one is always there. The 8/9 o clock and the 2 o clock ones are fainter but usually there as well. They have been extremely annoying as they are rather faint but RangeSelection still picks up on them when I'm trying to pick up on faint objects. I probably have to scrap the projects (or post them then revisit). I can't confirm if this is always happening since some of my other projects are shorter but it seems like anything over 5 hours in UVIR has it.
Some Examples please excuse the funny gradients, I used Gradient correction before cropping sometimes.
UVIR Cut 184x180s
UVIR Cut 198x180s
UVIR Cut 65x300s last night
UVIR Cut 8x300s (not present)
UVIR Cut 208x30s (not present but there is a star halo)
I HIGHLY suspect that it's my UV/IR cut filter (which I only use because it has the same thickness as my other filters so I don't have to adjust the backspacing in my wheel). From some tests on super bright stars, the halo from it is way more defined than my other filters. However, I would like to learn about what else it could possibly be. My other filters SiiHb, SiiOiii, HaOiii, Quadband do not seem to cause this problem. I also have not changed up my imaging train, rotated it, or opened it in a while.
Equipment in the imaging train:
Skywatcher Esprit 120ED
Skywatcher 1x Flattener
ZWO EFW 5x2in
ASKAR Backfocus adjuster M54
SvBony UV/IR Cut
SvBony Sv220
Antlia Quadband
Antlia SiiHb ALP-T
Altair SiiOiii
ZWO ASI2600MC Duo
Thanks for reading and any advice is welcome!
UVIR Cut 184x180s
UVIR Cut 198x180s
ZWO EFW 5x2in
SvBony UV/IR Cut
SvBony Sv220
Antlia Quadband
Antlia SiiHb ALP-T
Altair SiiOiii
ZWO ASI2600MC Duo
