Jeffery Richards:
As the topic implies, I am looking for help in choosing a complimentary refractor to my AGOptical 14.5" iDK (2464mm) to be used in a side-by-side tandem setup at a remote site. The goal is a high quality (prefer readily available) wide field scope. I was thinking something along the lines of a baby FSQ or Stellarvue 102T Raptor. I would likely be using a APS-C camera with it initially but might switch to full frame at some point.
Let the fun begin! Thanks!
**hi
here is one of my setup
takahashi baby-Q FSQ 85 EDX ( 450mm) flat 1.0x or RD-QB 0.73x New reducer for "Baby-Q ( 328mm)
camera zwo 6200 full frame, chroma filter 50mm ( 3nm ) SQM 16.84
perfect corners , just need some precision with the back focus( with Fine-Adjustment Rings) ,and the pattern light house ( big stars) live with that
and M54 for all imaging train , if you need more info let me know
with asi air pro plus you can use full frame ,or APS-C FOV, selector mode
now I'm moving for NINA
CS, Brian
