ZWO AM3 and ASCOM drivers
3 replies154 views
Philippe Barraud avatar
My AM3 mount in remote connects normally with ASI Studio, like the other devices (camera, focuser, filter wheel…)
But how to have it slew to a specific object in the sky ? There is no way to do it with ASI Studio.
There are many good softwares and planetariums, but all of them use ASCOM drivers. For some reason, my ASCOM Platform has defects and does not permit the use of the ZWO ASCOM drivers.
Updating the ASCOM Platform is possible only if the current Platform works normally ! So, I cannot remove it nor update it. Welcome to the absurd digital world…
Apart from putting my computer to the garbage, I wonder if someone could suggest a solution permitting to control the mount without ASCOM drivers.
Philippe
Ggj avatar
Hi Philippe,
Have you resolve your issue with ASCOM drivers?
I think all astronomycal gear needs ASCOM platform to connect to PC. It's really weird you couldn't reinstall ASCOM.
Alternatives are trying astroberry ( raspberry hardware) or ASI Air.
Good luck.
Actually, no ! But now I am using Asiair emulated by Bluestacks on my PC and it works fine (once you get rid of an avalanche of commercials…)
Thanks
Philippe
Since ASIAIR normally doesn't run on anything but a phone or a tablet I think that's kind cool. Glad you found a solution. There should be a solution to your ASCOM problem though. still, it might be a good excuse to to spring for an ASIAIR or a mini-PC.
My typical setup sequence in the backyard
Just sharing for any beginners out there. This is typically how I go about setting up and capturing for the night from scratch: 1) Take the tripod out, put it on my patio and point it as near to north as I can 2) Level the tripod using it's leg e...
Relevant for ASCOM driver setup with equatorial mounts.
Jul 14, 2022
