Eric Gagne avatar
Hello AB,
I installed a ZWO EAF on my Evolux 62ED but the focuser is jiggling inside the tube when the lock screws are removed.   Does this happen on most scope or is mine just as bad a scope as I now think it is ?   Won't this induce tilt and screw up my stars ?
Is there a solution or do I have to kiss the EAF goodbye until a get a better scope ?
https://drive.google.com/file/d/1GVPpnUjKMIpS-9LsTq0McLHCqx3Vyuoe/view?usp=sharing
Eric Gagne avatar
I guess googling first instead of panicking first would have been the right thing to do    Problem fixed, at least until I check collimation but I am leaving it here in case other people ever have the same issue.
The solution was in the 3rd post in this threadon CN.
One of the screws was very loose, I tightened it and it's not wobbling anymore.  I just hope it's straight because the other screw is stripped and no hex key will grab so I have only 1 screw for adjustment.
Andromeda Help
I am trying to figure out if my data is bad or my editing process is bad (or both). I'd love some feedback. Attached you will find my best edit, it is about 3 hours of data with a Nikon D850 unmodded and a Nikon 200-500mm at 500mm f5.6. I use 5 m...
Photoshop workflow help! — Hello! I'm a newbie, started in Oct 2023, and has been doing my best with Photoshop (it's free with my work and I can't afford PI yet). I learned a l
Aug 26, 2022
