"Bubble" spots on images
2 replies200 views
Carlo Paschetto avatar
Hi all,
one of the issues I'm used to deal with it's due to spots on the images shaped as large bubbles, which I experience with different distribution and size depending on the camera I use. The attached image shows an example just taken with an almost brand new ASI533MC Pro, which perhaps I used nno more than 5 o 6 times.
I'm wondering whether these bubbles are most probably due to spots on the camera sensors or to the telescope / flattener lenses. At a first sight, lenses seem to be perfectly clean, but on the other hand the 533MC is almost new.
I have often noticed the same effect using my Canon DSLR. I sent it to a laboratory for the sensor to be cleaned and the situation seemed to be improved, but after a couple of sessions small bubbles have begun to appear again.
Of course, same bubbles appear by shooting the flat frames and btw using flats helps to reduce the problem in the final image. Nevertheless I'm wondering which cause I should probably look at and the best way to avoid this issue.
Than you got your tips and support.
Habib Sekha avatar
These are dust specs (although condensation droplets can look the same).
Take a Flat, rotate at the rotator and take another Flat. If the position of the specks changes the tey are located between the rotator and camera. Now you could try the same but by only rotating the camera.
Dust can be on the protecting glass of the camera, filters, reducer/flattener etc.
Dale Penkala avatar
Agree with @Habib Sekha these are dust motes. Take flats and they should calibrate out for you.
Secondary mirror coating issue or possible light leak problem?
I was considering sending my secondary for my ago idk 14.5" over to terry at ostahowski optics for a recoat because if I look closely enough, I have what looks like an oil spot or something that slightly dulled a small part of my secondary coating th...
Secondary mirror coating or light leak could cause bubble-shaped artifacts in images.
Nov 3, 2025
PixInsight WBPP - dust motes/donut still not cleaned with flats
Hello, I am still seeing dust motes/donut shaped spots even after calibrating with flats. I tried few exposures with flats but no improvement. I use dark, bias and flat calibration frames and default wbpp settings. from the attached screenshot, you c...
Dust motes and donut-shaped spots similar to author's bubble issue; flats calibration relevant.
Sep 30, 2025
Odd "circle" in imagery when taking photos
Hi all, Starting with: This is a 12” newtonian (1200mm), with a Poseidon-M connected to 50mm (round) filters and an OAG-MAX (with a coma corrector) - 56mm back focus So I’ve been banging my head against a wall trying to figure out what this is… I fir...
Circular artifacts in imagery; similar diagnostic problem to author's bubble spots.
Mar 13, 2026
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
Doughnut artifact in camera images; similar issue with ZWO ASI camera model.
Nov 27, 2025
Help with dust on QHY600M sensor after cleaning attempt
Seeking advice regarding dust on QHY600M sensor and sensor window. This is one of those “The enemy of good is better” stories. I am truly embarrassed and feeling very sad. Several days ago I noticed ice crystals on my QHY600M sensor window. So I used...
Dust on sensor causes artifacts; relevant to determining sensor versus optics source.
Oct 8, 2025
