533mc Pro - Terrible Reddish Artifacts
Aymen AissaHassaan Zaheerandrea tasselliDave BBensAstroStuff
33 replies1.6k views
Aymen Aissa avatar
Hi everyone,
I’m experiencing an issue with my 533mc Pro camera and could use some advice. When I take RGB pictures using the Antlia Quandband filter, I notice two large reddish areas in my images. This problem persists even in my flats, and the WBPP process doesn’t seem to eliminate these artifacts.
Interestingly, the same reddish areas appear when I shoot without filters as well. However, when I switch to narrowband (NB) imaging, these artifacts become much less pronounced.
I’ve tried all sorts of gradient removal techniques, but the reddish areas just turn white and the background remains unclean.
Has anyone encountered a similar issue or have any suggestions on how to address this? Any feedback would be greatly appreciated!
Thanks in advance for your help.
You obviously have a signficant amount of LP if flats don't work. Try using Graxpert.
Armin Lukas avatar
Could you share more information about your settings like gain, exposure time etc.?
Craig Dixon avatar
I see similar effects to that in my lights and flats from my ASI533MC Pro but only in the auto-stretched jpegs that ASIAir produces for previews. If you open a single sub in pix insight and do an STF do you see the same result?
BensAstroStuff avatar
I'm curious, how are you taking your flat frame? Are you using a light panel?
Aymen Aissa avatar
Craig Dixon:
I can see that we share almost the same setup (190MN + 533MC Pro). The 60s subframe i shared is stretched on PI.
Aymen Aissa avatar
Yes, using a light panel and a white shirt. I'm following the same practice for my NB as well.
Aymen Aissa avatar
Armin Lukas:
I'm using Skywatcher 190MN with 533mc pro cooled at -5 and 100 gain. I'm at Bortle 8 so i usually don't tend to exceed 60sec when i shot RGB.
Aymen Aissa:
That's exactly how I do it.
I would suggest removing the camera from the system, putting it on a bench, and take a 'flat' with nothing else attached. If this is an issue with the camera, it will show up there as well.
Since the pattern looks identical in your flat and light frames, it's either in your optical train or the camera itself.
Daniel Tomcej avatar
My flats look very similar to yours when I use my 533MC.
You need to ensure that your flats are ~30k-35K ADU. If they are too bright, they overcorrect, resulting in the "whitening" overcorrection you see.
I take flats with sheets of white paper that I can add/remove pieces until I get an average ADU in that 30-35k range.
What caused me issues when I was troubleshooting is that it is not immediately apparent from the stretched flat what the average value is.
You may be able to "save" your flats by modifying the master flat to reduce the ADU, or you may want to retake them.
Well Written Helpful Insightful Concise Supportive
Aymen Aissa avatar
Daniel Tomcej:
Thanks for the insight, Daniel. I will have a look at my flats and let you know the poutcome.
Aymen Aissa avatar
Aymen Aissa:
*Ideally flats are meant to correct all these patterns as the noise/artifact will be subtracted during the stacking process. As Daniel mentioned, I will check if my flats are over correcting the lights.
Aymen Aissa:
Aymen Aissa:
Sorry, I assumed the light frame you shared was not corrected by the flat, and that this pattern was showing up in both light and flat frames. If it's showing up in your uncorrected light frames, it's not going to be caused by flat over-correction. You're not getting anywhere near 1/2 your well depth in the dark areas of your light frame.
Dave B avatar
How long are your flat exposures and what is your gain setting , I set Adu  at 35 k Adu but for cmos cameras you need a exposer of 3 seconds or more (Adam Block recommends for cmos cameras it’s in one of these videos 3 part series) obviously you may need to experiment to get the correct exposure/Adu value with more or less paper unless you can adjust the flat panel brightness , I’m assuming you’re not using a coma corrector if your using a MN 190
https://youtu.be/Kkg441UBNpo?feature=shared
Dave
DarkSkyTim avatar
Jumping in late here…are you using a dark library to calibrate your images with darks? I was having a similar issue with my 533MC Pro and L-extreme filter where my flats were not calibrated properly and it was suggested that I try shooting new darks. My dark library was 12 months old and I used the new FBPP in Pixinsight to calibrate and stack my images and the issue was solved. I used FBPP with both my old and new darks and with the minimal configurable settings to change the variables between each integration which leads me to believe the issue was with my dark frames. That was interesting to me.
Brian Puhl avatar
Hey,  I'll jump in on the late bandwagon here as well.
I don't think you have a flat issue.     I believe what you're picking up is a stray red light from your mount somewhere, or something near by.    Tape up all your red lights, or turn them off if possible, and try again.
**Edit:   Maybe not, since it's actually present in your flats, I thought it was just lights.   I misread.   Sorry.
Hassaan Zaheer avatar
Hi Everyone
First Light, First time user of a cooled camera,
I am using the QHY 533 color camera.
This is a stacked image of about 4 hours of data,
the image above is only calibrated with dark frames.
I did used flats and dark flats to remove the artifacts but i am not able to remove the square shape gradient.
The camera was cooled to -10 degrees.
The flats were almost 3 seconds long(Taken with NINA flat assistance).
Gain 68
Offset 20
I am processing in pixinsight and using DBE but i cannot get rid of this.
What am i doing wrong here
Telescope REDCAT51
Dave B avatar
Did you  crop the border so no stacking artefacts  , your flats aren’t working either what program did you stack with?
Dave
Rajat Kumar avatar
Hassaan Zaheer:
Hi Everyone
Gain 68
Offset 20
Telescope REDCAT51
There is something in your settings because of which flats are not calibrating. Check PI settings. This is not calibrated at all. Even the 'square shape gradient' will be taken care of with flat calibration. If you can post your calibration frames and settings on PI then people may be able to help.
Rajat Kumar:
Hassaan Zaheer:
Hi Everyone
Gain 68
Offset 20
Telescope REDCAT51
so sorry, but i forgot to mention that the image is not callibrated at all, i was just showing the original image to show the extent of the issue.
Dave B:
Dave
no i did not crop the borders.
As this is my first image with a cooled camera ever. I was under the impression that the image would not need to be cropped and would be free of such artifacts
Dave B avatar
Hassaan Zaheer:
Dave B:
Dave
No you still need to crop , think of it like stacking a sliced loaf there will be slices not exactly aligned .
Dave
Hassaan Zaheer:
To th extent where there is some random overlapping you won't need to crop the image if you used LocalNormalization (best) or some other form of re-normalization during the image stacking. This isn't dependent on whether the camera is cooled or not.
This looks like an over-stretched. non-calibrated stack to me. Cooling is nice because it simplifies darks and reduces noise but it's not a magic. You still have to calibrate and process properly. Do all that and post the result.
Marc-Antonio Fischer avatar
These reddish artifacts are not caused by the camera. Its the fault of the filter, because its not 100% evenly manufactured. I would suggest you not using that filter anyways on a galaxy like that by the way.
ike the others says, you still got a huge callibration error, often caused by straylight when you capturing flats during day, or wrong bias frames. Make sure you cool the flats and bias to the same temperture as the lights. This solved the problem for me.
Solar Limb Darkening
Using my ASI178MM camera. I see some limb darkening on my photos, but it's not gradual. I see an area that looks like a border on the Sun but it's not all the way around the disk. When I rotate the camera the area rotates with the camera. I h...
Camera artifact issue with similar imaging setup and equipment configuration.
Dec 1, 2022
Green banding issue in WBPP when using flats
Does anyone know what might be causing this green banding? I’ve never encountered this issue before, and it disappears when I exclude flats from WBPP. I have inspected my flats, and they seem normal. I’ve yet to try retaking the flats or do more test...
Green banding issue in WBPP when using flats — similar WBPP artifact problem with persistent structures.
Feb 7, 2026
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
ZWO ASI 2600MC producing doughnut artifact in center of images — camera-specific artifact in center of images.
Nov 27, 2025
Comet Lemmon Data Up for Review – Banding / Pixelation Issue
I’m returning to DSO astrophotography after nearly eight years away, and needless to say, my PixInsight skills needed quite a bit of refreshing. I’m using the same setup as before, but I’ve switched to a Sony A7 IV DSLR for imaging because of its ver...
Comet Lemmon Data Up for Review – Banding / Pixelation Issue — persistent artifacts in stacked images despite processing.
Oct 14, 2025
