Tom Boyd:
Just to throw in my experience. Moving to 1.8.9.3 broke my instance of the nbcolourmapper script. Reverted back to 1.8.9.2 with no problems...
All my CosmicPhotons scripts and processes are now up and running through the repository system, including nbcolourmapper.
Gaillard Jérôme:
I've got problem with the script "Foraxx Palette Utility". What can I do ? Thank you a lot.
I'm sure Paulyman will be updating his repository in due course. Until then you can download the script from
here and install manually. If you are not familiar with manual installation of scripts here is a step by step guide:
Download the directory from Paul's google drive linked above.
Add the ForaxxPalette directory (not just the ForaxxPalette.js file) to your PixInsight/src/scripts directory
In PixInsight go to the Script menu and click on Feature Scripts
Click on the Add button at the bottom left of the dialog
Navigate to the src/scripts folder and click Open
PixInsight should say that it has found an additional script
Click Done
Quit and restart PixInsight
The Foraxx Pallette script should now be in Script>Utilities
Toolbox scriptsJurgen is working on these and they should be available before long - see
this link.
I hope these comments are helpful
Mike
