M42 lenses + ASI2600MC Pro
3 replies168 views
Alien_Enthusiast avatar
Dear AstroBinners,
I have a question regarding the compatibility of vintage M42 camera lenses with the ZWO ASI2600MC Pro camera.
According to sources, the so-called "flange distance" of M42 lenses is 45.46mm
The 2600 camera has 17.5mm between its sensor and the M42 thread
My question is simple - will the M42 lens work with it?
Would I simply attach the lens to the camera directly? Would I need to use spacers? Would the distance between the lens and camera have to be exactly 55mm?
Here is the image of the M42 lens;
Christian Großmann avatar
the answer is, that the distance from the sensor to the back of the lens (not to the thread) must be 45.56mm. So you need an adapter to get this value. I never saw such an adapter, but they might be available somewhere.
In my experience, M42 lenses may not be the best option for your camera. I tried them with my DSLRs several times and they are usually quite soft and have other issues that even cheaper modern lenses do not have. I don't know which lens you plan to use, but they might be at least three decades old. I assume, they are even older. During this period of time, photography changed significantly and digital sensors need other optical designs. So unless you are doing it just for fun, it may be worth thinking about another way of getting the images you want. But I totally understand if you will give it a try smile
Christian
Jan Erik Vallestad avatar
Christian already gave the only right answer here, the flange focal distance on the different lenses are absolute. The idea of 55mm doesn't apply to lenses in general. Wikipedia has a good general description as well as a list of all common mounts: https://en.wikipedia.org/wiki/Flange_focal_distance
As long as the flange focal distance of the lens is more than the 17,5mm on your camera you can adapt it. Just subtract the 17,5mm and then you have the right amount of space you need to fill in, remember to factor in 1/3 of the filter thickness as well if you use any.
There are several good vintage lenses out there. Some of the small Takumar tele-lenses have been known to be quite good. I used an 80s Nikkor 135mm lens that also weren't bad. I know I had some other suggestions here on Astrobin a while back as well, but sadly I couldn't find it atm.
Christian Andres avatar
There is also the issue with different thread pitch between the two standards. The vintage M42-mount comes with M42x1 whereas the "T-mount" (T2) is M42x0.75. Keep that in mind while looking for an adapter.
Well Written Helpful Concise
OAG setup with 585mm lens requires 10mm spacer for proper focus
Hey there! I wanted to try out an OAG with my 585mm and the SV555. Yes I know no need for OAG with this focal length but since I have to carry everything up a ladder to the roof I figured smaller would help My problem now is that I had to put a space...
Discusses spacer usage with camera lenses, directly relevant to flange distance problem.
Dec 30, 2025
Setup changes
I know it might be a stupid dilemma but lately i was thinking about changing my camera, was torn between two possible choices, the ZWO2600 or 533, both mounted on an Askar 91F, as regards the 533 i would have taken the 0.75x focal reducer which bring...
Mentions ZWO2600 camera setup and configuration considerations.
22 days ago
