I started in this hobby about 18months ago - with my primary area of interest being DSOs. I have an Esprit 100 and a GSO RC8.
Last night, I tried out my hand at planetary imaging for the first time, using a 2 x Barlow in my RC8 to give a focal length of 3200mm at f/16.
Here is there picture Jupiter I obtained with my ZWO ASI462MC camera (2.7um pix), running in video model (1024 HD format). Frame times were 50ms and gain 250. I tried other combinations, 420 format, 10ms frame time/gain 380. But all turned out looking pretty much the same. Data was processed in Autostakkert and Registax (great programs). Videos contained from 2000-7000 frames and I used the 10% best. (Also tried 5%, 20% and 50% best - again with little apparent difference, although the 5% best image was a bit noisier.)
I am quite happy with the way my first image at 3200mm focal length turned out, since my site has pretty poor seeing (3-4arcsec) and I suspect the RC is not the best to attempt planetary imaging with.
Notwithstanding that, I was able to get to the resolution limit of the RC (0.57arcsec), corresponding to 3 pix on the detector. Note that I did't drizzle on the basis I was oversampling physics, let alone the seeing! However, I would value any suggestion for imporvement. My image lacks the wow! factor of many out there.
It could be many things
1) the seeing at my site (can't do anything about that)
2) the type/aperture of telescope (that will need to wait)
3) the observing approach
4) the processing
With many thanks in advance
CS Brian
4) the processing
CS Brian
