56.2mm backfocus
5 replies•242 views
ZoboZodiac avatar
Hi all, I recently started using an FSQ-85 with the edp flattener and I’m just trying to figure out what people do with the back focus. I see in the manual that the back focus is supposed to be 56.2mm and this is 1.2mm more than the standard 55mm.
I’m pairing a ZWO 2600mc duo with it, but at the moment I’m just using 55mm as they’re the adapters which came with it.
What do people usually do with this back focus? It seems most of the Takahashi scopes use 56.2mm but I can’t find many examples of what spacers people actually use in practice
Mariusz Golebiewski avatar
Something like this can be useful: Baader T-2 adjustment/spacer-rings
Bruce Donzanti avatar
Backfocus on the FSQ-85 is extremely sensitive.  I also added 1/3 of my filter thickness to the 56.2mm and used thin spacers like the ones Mariusz mentions above.  There are others I like a little better that you can purchase from Agena Astro.   Take your time to get the backfocus correct.  You won't regret it.
Well Written Concise Supportive
ZoboZodiac avatar
Thank you both, I’ll have a look at getting some of those spacer rings. I’m sure it’s a non issue, but because they take away a little bit of thread have you ever noticed things being a bit less secure with them on? I’m assuming it’s not an issue in practice
Willem Jan Drijfhout avatar
That's a good point and it greatly depends on the extension tubes you're using. For example, I use both Baader M68 and M48 tubes. The M68 have a very generous length of thread, easy to add 1-1.5mm of spacer ring. The M48 tubes have much less thread, and I would not add more than 0.5mm to them.
Well Written Helpful Concise
Takahashi-scopes all come with system charts, which show which adapters/spacers you need for which configuration. In almost all of them, there is an option that gets you to a DSLR mount, for example Canon EF. On the camera-side, manufacturers such as ZWO almost always have an adapter in their portfolio that give you the same for example EF mount, including the standard EF sensor distance (44mm). So it will give you the back focus distance that you need, with the added benefit of an easy-to-use bayonet-coupling to put the camera on. I have done this for a long time, and served me well, until I started adding tilt-correctors etc.
Dual narrowband imaging issue
I'm new to using dual-narrowband filters in combination with a OSC camera, and I'm faced with the following problem. During one of the last sessions, I used an Antlia ALP-T 3nm Ha-OIII filter with a ToupTek ATR2600C camera. The filter is inst...
Not relevant - focuses on narrowband filters, not back focus mechanics.
Aug 6, 2025
External focuser on an SCT; What about temperature change induced focal shift and back-focus?
It seems like every serious astro-photographer is putting external focusers on the back of the EdgeHD telescopes and locking the mirrors. I picked up a nice little EdgeHD 8" and a Primaluce Lab Esatto 2" LP focuser and gave it a try myself....
Relevant - discusses back-focus adjustment and temperature-induced focal shift issues.
15 days ago
