Smoothness of RA motion on a one second timescale in mounts . What is normal?
1 reply209 views
Tim Hawkes avatar
I suspect that I might have a continuing problem with an RA oscillation in the movement of my Ioptron CEM70?  It can be an explanation for Eccentric star shapes elongated along the RA axis direction.  Interested to know if others have experienced or detected anything similar in their mounts?
Previously ....in an earlier-model  CEM70 mount - now returned -  at about 1s intervals there was a regular rapid ~ 1.5-2 arcsec detour in RA that then quickly settled  back to the mean until the next cycle on the following second.  This appeared to distribute some of the light along the RA axis making stars  appear elliptical.   The problem did not show up in PHD2 guiding because that only resolves movement on a 2-3s timescale .
I only discovered this RA oscillation after carrying out quite a few experiments a couple of years ago with the first CEM70 mount that I had before it was replaced (much to their credit and without any fuss by First Light Optics)  - the problem with the first  being 1.5-2 arcsec oscilations accompanied by a faint clicking sound.
When imaging 'normally'  at resolutions above 1.0  arcsec / pixel the problem was hardly visible in terms of its effect upon star shape.  However down at 0.4-0.5 arcsec pixel the problem  became more obvious with star shape Eccentricities averaging at 0.5 - 0.6  and r of PSFs ~ 0.8- 0.85 across the field.
Interested to know if this second-scale oscillation in RA  movement was just a freak occurence with my particular set up -- or something that others have seen too
Tim
I thought it might possibly also be useful to append some parts of a presentation I did on the original diagnosis of the problem?  The set up was a PDS200  (f=1000 mm)  on the original CEM70 mount  and movements monitored with an ASI294 MM camera at 2.315 u pixel size.  Hopefully it is self explanatory ... I used the  grid of sensor pixels to track what the scope and mount were doing every 100ms over a 60s period.
Tim Hawkes avatar
This is an orphan thread – but a quick update and a correction just  in case anyone had logged it.
I do not in fact appear to have the same oscillation problem with the new CEM70 mount as  with the original.   Although the star shape problem with elongation along the RA axis appeared similar the cause appears to have been different this time.
Suddenly I am back to round stars with Eccentricity < 0.4 .   Not at all sure of the cause of the ongoing problem earlier this year but the changes were  –
1) Fine tuning the mount balance in 3D  – attaching weights to the telescope to get everything just right  -  this may have been additionally imporatant because I was pushing the mount weight limits for imaging.
2) The sudden return of better skies – brighter images, less high cloud stiller air?
Tim
Ioptron Sky Guider Pro DEC Oscillating Error
Does anybody experience the same? When guiding RA with PHD2 (DEC has no motor), I am experiencing periodic oscillation showing in DEC (I am not talking about RA) with p-v over 12 arcsec, sometimes even more (see the first picture, DEC curve is yellow...
Relevant; discusses RA oscillation problems in mounts similar to author's concern.
Oct 28, 2022
Unguided Periodic Error with SW SA gti?
My initial test reveals significant periodic movement in RA direction. I see a period of about 7 minutes. Is this the worm period? I had to reduce the exposure to 30 seconds to make stars less elongated. That led to 540 subs and a very long time to s...
Discusses RA oscillation problems in mounts; directly relevant to periodic RA movement issue.
Oct 31, 2022
Effects of leaving mount outside during the day
One day a few weeks ago I left my mount hooked up outside under a semi-reflective nylon cover. I took the OTA and camera gear off and brought that stuff inside. By dusk, my mount was still very warm, and I'm wondering if any damage may have happe...
Directly addresses RA oscillation issues and guiding problems similar to author's experience.
Sep 9, 2022
SkyGuider Pro not tracking > RA motor calibration
After a year using the SkyGuider Pro without any major issue, I've experienced some technical difficulties yesterday night. After successfully tracking for after hour on my first target, I re-positioned my scope an a second target. When starting ...
RA motion issues could relate to tracking problems on mounts.
Jun 25, 2022
CEM70 guiding curve
Hello there, I have asked this question already in another post, put the session got sort of hijacked, so I try it again here. I am using PHD2 for guiding my CEM70 mount. phdlogview is able to calculate a nice raw guiding curve without corrections ex...
RA oscillation could explain discrepancy between guiding curves and mount PE.
Oct 13, 2022
