Gamaholjad avatar
I wonder if some could help please. I've had to build a new pc and in process have to reinstall all my software. My question is I cannot get my celestron cgxl to be noticed in the mount selection on phd2. Ascom drivers for everything is installed so I've curious how to select my mount to connect to phd2. The mount is connected via a USB connection as opposed to connecting through the handset.
I did notice that options for mounts had changed in phd2.
Tobiasz avatar
did you install the celestron software CPWI? You need to connect the mount via CPWI first so it can be recognized by PHD2 properly. That is how it works with my CGX, which electronically is the same as the bigger L cousin.
Regards
Gamaholjad avatar
Yep connected via cpwi, and is recognise in sharpcap.  There's no option for cpwi in the mount selection in phd2 its weriod.
TiffsAndAstro avatar
check the usb lead. Usb cables just seem flakey in general.
Baud Rate for EQASCOM with AZ-EQ5-GT
Last night I was hoping for some trouble free autoguiding as I thought I had my problems ironed out…but no! I was running PHD2, EQMOD and SharpCap Pro on my Windows 10 laptop. A Lynx Astro FTDI EQDIR USB Adapter for Sky-Watcher Mounts connected...
PHD2 software reinstallation; author actively uses PHD2 for autoguiding
Jul 4, 2022
